how 2 fit bov 2 a 4agze?
Postby dimmy » Fri Jun 11, 2004 4:04 pm
:?: i have heard it is possible 2 fit a blowoff 2 a 4agze do u take off the standard abv and fit 1 there or is there another way? also do i use a type 1 bov?
dimmy
Postby Lloyd » Fri Jun 11, 2004 4:22 pm
Its pointless, dont even bother.
Postby Distrb » Fri Jun 11, 2004 4:24 pm
HRT wrote:Its pointless, dont even bother.
Amen 8)
Bov's are for turbos only.....
Distrb
Regular Poster
Postby dimmy » Fri Jun 11, 2004 4:52 pm
i know there is no point except 4 da sound
dimmy
Postby Lloyd » Fri Jun 11, 2004 5:03 pm
No, you dont get the sound. In a turbo when you close the throttle pressure builds up because the throttle is closed and the turbo is still spinning. You dont have that problem in a supercharger setup as there isn't the pressure there to vent. No point to putting one on, unless you want to make it look pretty of course :roll:
Postby FLAWLES » Fri Jun 11, 2004 6:20 pm
get a glimer belt drive
thats wot im doing " well getting one custome made "
bov are for turbos
FLAWLES
Postby dimmy » Fri Jun 11, 2004 6:42 pm
wots a glimer belt drive and wot does it do ???????????
dimmy
Postby FLAWLES » Fri Jun 11, 2004 6:51 pm
ever herd a rotary or a s/c v8 with a funny buzzing nosie well thats a belt drive basicly they goes on your crank/alternator/water pump/s charger etc they also can be a bit liter
also on the v8 its mostly straight cut timing gears but this is only going to confuse you???
FLAWLES
