Old tvis 4age motors...
Postby Pies » Thu Jun 17, 2004 6:37 pm
can someone tell me the differences between the blue top tvis 4age and the red/black top tvis 4age? and are the ECU's and loom's compatible?
churs
Current Rides:
Pies
Postby skoty » Thu Jun 17, 2004 9:27 pm
Red/black top has stronger bottom end internals compared to the blue top, and yes the looms and ecu's are interchangable although the plug-in adapters will need to be changed.
Profile - Cars Owned - AE82 Corolla GT / Corolla Dirt Track Car / N14 Pulsar GTI / S14 Silvia Qs / Nissan Van / Nissan Avenir GT
Current cars - Altezza RS200 and Mitsi Lancer GSR
skoty
Postby badidas » Thu Jun 17, 2004 11:25 pm
the best ecu would have to be the one from corona"s with the 4age (type 41 ?)
1989 mazda bongo aka [BNGBUS]
badidas
Postby gdsup » Fri Jun 18, 2004 12:18 am
red/black top have better crank and heavier block, looms and ecu's are not entirely interchangable, ie use must use 1 or the other full system, they run different injectors sizes and ignitors etc, the ecu badidass is talking bout is type 61, last 2 digits on the label, and is bluetop system
gdsup
Postby RedMist » Fri Jun 18, 2004 9:17 am
Possibly the easiest way to tell the difference (other than the covers, which isn't always reliable) is the ribs on the block. The bluetop has 3 ribs and the redtop bigport or the red and blacktop has seven. Redtop bigport internals are stronger... however if you can, and your after the best of the NA world develop a smallport. Its a better engine than a developed 20 valve. For compressed applications I'd be heading blacktop 20 valve, but I don't like compressors!!
Daniel.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Pies » Fri Jun 18, 2004 2:05 pm
gdsup wrote:red/black top have better crank and heavier block, looms and ecu's are not entirely interchangable, ie use must use 1 or the other full system, they run different injectors sizes and ignitors etc, the ecu badidass is talking bout is type 61, last 2 digits on the label, and is bluetop system
so id be better off sticking with the blue top ecu and loom and it would all be sweet? whats the difference between injectors?? resistance? or does one set pump more gas?
Current Rides:
Pies
Postby Mr Revhead » Fri Jun 18, 2004 3:23 pm
late bluetop 4ages can have the same rods as the tvis redtops... cranks changes in the 7th month 87.
best to stick to ya std injectors and loom unless youv done the cams etc, redtop non tvis injectors have different plugs and are apparantly higher flow.
Postby 86 Power » Fri Jun 18, 2004 5:44 pm
Mr Revhead wrote:redtop non tvis injectors have different plugs and are apparantly higher flow.
Can you confirm this? Do you know exactly how much more? Or is it just because of the fuel pressure reg being of a higher pressure?
86 Power
Postby Mr Revhead » Sat Jun 19, 2004 10:15 am
iv been told by more than one person who i trust.... but note i said apparantly... means im not 100% sure.... lets say 95% :D
i remember reading it some where too but cant remember where...
Postby 86 Power » Sat Jun 19, 2004 9:31 pm
Decided to not be lazy, researched it myself from www.club4ag.com...
4A-GEU AE86 (84-85) 182cc 1 Ohm
Fuel Pressure Regulator 2.55kg/cm2
4A-GELU AE92 (88-89) 182cc 2 Ohm
So it seems to be just higher impedance not flow. Annoying, because I have some and wish they were higher flow.
86 Power
Postby NA Drifter » Sun Jun 20, 2004 7:28 am
4A-GEU/GELU Technical Specifications OEM
AE86 (84-85)
(AE86 86-87, AW11)
AE92 (88-89)
AE92 (90-91)
AE101 Japan (92-95)
AE111 Japan (96-2000)
Injector Size
182cc
182cc
182cc
235cc
295cc
295cc
Injector Impedance
1 Ohm
1 Ohm
2 Ohm
2 Ohm
2 Ohm
2 Ohm
Injector Type
Top Feeder
Top Feeder
Top Feeder
Top Feeder
Side Feed
Side Feed
2.55kg/cm2
2.55kg/cm2
2.55 kg/cm2
2.9 kg/cm2
2.55 kg/cm2
2.55 kg/cm2
OEM Spark Plug
BCPR5EP11
BCPR5EP11
BCPR5EP11
BKR6EP8
BKR6EP11
BKR6EP11
Misc.
TVIS 8 port
TVIS 8 port
TVIS 8 port
4 port
Indiv. Throttle, VVT
light flywheel VVT
http://www.club4ag.com/faq%20and%20tech_pages/4A-GE_technical_specifications.htm
Keith
NA Drifter
Postby Drifter4ag » Sun Jun 20, 2004 12:47 pm
wooohoooo .. go 2.9bar reg .. shizzle nizzle
Get a bluetop
Red Black Top/Late model bluetop / TVIS REDTOP what ever you wanna call it just has larger crank and rods .. pistons same as bluetop but will have different part number as they fit a 20mm gudgeon. The TVIS redtop ecu has same plugs as early bluetops and will run an early engine with std loom and injectors .. but it will run bad and go lean.
Bluetop is the best 4age for any application
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
JZX91 MARK II CHASER
Drifter4ag
