Weird 20v noises..
Weird 20v noises..
Postby strap-on » Mon Jun 21, 2004 9:11 pm
k my 20v makes a collection of weird noises and i was wondering if neone can help me figure out wat that are..
1) noisy belt:
its not squeliing, just makes a lot of noise, specially when the engine is cold, i traced it to the alternator i think.
2) sometimes weird crunching noise after ignition
sometimes when car is cold, is makes a crunching noise after it has started, similar to that made when u turn the ignition when car is already running ( not that i ever do this)
3) my car sounds like a tractor.
the head, makes a real noisy tapping sound, cn hear it from in the cabin.
so ne ideas what these noises are and how to fix?
strap-on
Postby Al » Mon Jun 21, 2004 9:17 pm
cambelt idler
when mine wasnt setup properly it made the same noises as you have described.
Al
Postby Smoken » Mon Jun 21, 2004 10:07 pm
hey man
the grounchin could be the starter motor not diaingagin (cant spell sorry) not cummont out from the flywheel /// FIX get the starter motor checked out
the tappin could ither be the vvt cam trigger or ither the can where
if u cant beet em bash em!!!!!!
Smoken
Postby spencer » Tue Jun 22, 2004 10:37 am
yea my 20v also had a problem with cambelt idler made alot of noise, also i guess you could check the valve clearance could make the tapping noise. Sounds like your starter is not disengaging as above
ms63 crown
spencer
Postby Mr Revhead » Tue Jun 22, 2004 2:24 pm
the knocking will probably be the vvt pulley. not worth worrying about
as for the crunching..... :?
Postby strap-on » Tue Jun 22, 2004 3:39 pm
well i took it to my old work, and my old boss reckond the tapping was either tappets, or the shims, or the valve clearence, alougth he reckons toytas do that after a while, but we are changing my cam belt soon so i spose we can look then
strap-on
Postby Mr Revhead » Tue Jun 22, 2004 3:48 pm
they dont have tappets!
cam works directly on to the shims.. could be valve clearance but that wouldnt start all of a sudden. (thats what the shims do... adjust clearence)
its very common for the pulley to start knocking
Postby strap-on » Tue Jun 22, 2004 3:54 pm
well that narrows it down, what in the vvt pully makes that noise?,
dammit i gotta check my clerances now :(
strap-on
Postby Mr Revhead » Tue Jun 22, 2004 3:58 pm
they have fluid in them to dampen the knocking... it leaks...
doesnt affect the running at all.
Postby strap-on » Tue Jun 22, 2004 4:00 pm
will the knowcking come from the cam pulley? cos its not coming from that end, its definitaly underneath my rocker cover
strap-on
Postby Mr Revhead » Tue Jun 22, 2004 4:02 pm
sound travels in funny ways in engines.... it could very well be to do with valve clearances... mine does it sounds like it comes from about 1/3 of the way along the head... its the pulley in mine
Postby strap-on » Tue Jun 22, 2004 4:20 pm
is there ne way to replenish that fluid?
strap-on
Postby Mr Revhead » Tue Jun 22, 2004 4:25 pm
no its a sealed unit. for the price of the pulley just best to ignore it!
however u say you can hear it from inside the car.... if its the pulley you will probably only hear it at idle....
Postby strap-on » Tue Jun 22, 2004 4:40 pm
yup that sounds about rite, what is the price as a matter of interest?
lol im just trying to figure out why its useing oil, i just dont think it likes the shell helix, i might go back to the redline and see how that goes, have those oil filters come yet?
strap-on
Postby Mr Revhead » Tue Jun 22, 2004 4:48 pm
just sorting out a deal on those pulleys now...
but prob around $400-500.....
filters should be here soon...... i hope :?
supply seems a little erattic at the moment....
ill be sure to let ya know!
Postby Mr Revhead » Tue Jun 22, 2004 4:55 pm
well bugger $400 how about $200 delivered?
Postby strap-on » Tue Jun 22, 2004 5:03 pm
whats the 200 for?
strap-on
Postby Mr Revhead » Tue Jun 22, 2004 5:08 pm
the vvt pulley!!
i normally use castrol protec in mine, though i put helix plus in it on saturday as i forgot to buy some castrol before i drained the sump!
Postby 4ageman » Tue Jun 22, 2004 11:04 pm
all 4age's make a knocking sound from the engine as they get higer km's on them its the wear in the gudgion pin. its nothing to worry about.
4ageman
Postby strap-on » Wed Jun 23, 2004 12:32 am
so i should switch to plan b.... sell my car and buy a bzr? lol
strap-on
Users browsing this forum: No registered users and 29 guests
