lost wrote:He's from north shore so I doubt that's gonna work, plus he said hes got the engine.
I think the verdict is that the 20v intake isn't so good, its preferred to switch to an older 4age's (redtop?) intake. I don't know what specific parts you planned on using from the 4agze, but most will suggest that unless your keen to use the 20v head for originality factor, it's better to just use the whole 4agze setup (correct me if I'm wrong). Depends what you're after though.
Hope this helps. Cam
valves in the silvertop were made out of weak metal
