TRDmod wrote:reason i asked because there was a gt4 in my local toyota, having its engine replace because part of the turbo went into the engine.....thats y i asked
i would rather get a better turbo
TRDmod wrote:Doesn’t the st205 gt4 come with a high flow cat converter anyways? That’s what I got told by Toyota themselves, the cat converter on the gt4s 205 is already a high performance one…correct me if im wrong.
Heres one
If I decide not to remove the cat converter, and do the mods that we discussed, which si non ceramic shaft turbo enough for 1-.12 bar, so it wont be a large turbo, oil cooler and gauges, what would happen if I leave the can converter in there?
I have a 3 inch exhaust hks, would there be any difference in performance, if so how much if I get my muffler modified so I can remove it and attach a straight pipe with out muffler when im on the track, how much difference would this make, because it doesn’t cost much to do so, you jstu remove muffler and put a dual exhaust design straight pipe with out a muffler.
Rollux wrote:Correct me if I'm wrong, but isn't the ceramic turbine on the exhaust side? If so, how does your shattered ehaust wheel end up inside the engine? I would assume it does what Skylines do, spit lots of little ceramic bits into the exhaust pipe and out the muffler if it's straight enough.
How do these pieces crawl back against the gas flow and lodge in the engine?![]()
nemesis wrote:Rollux wrote:Correct me if I'm wrong, but isn't the ceramic turbine on the exhaust side? If so, how does your shattered ehaust wheel end up inside the engine? I would assume it does what Skylines do, spit lots of little ceramic bits into the exhaust pipe and out the muffler if it's straight enough.
Having seen the evidence of ceramic shards beating up the pistons and head, I can assure you it does happen. Exactly how, I'm not sure. As I said it seems to be a peculiar feature of the gen 3 3SGTE.
