4age + c52
4age + c52
Postby skoty » Sun Jun 27, 2004 4:16 pm
Just wondering...
Does the aw11 use a c52 g/box like the ae82 fxgt alongside the 4age? Therefore a 4age + c52 g/box combo would be able to be swapped between the two without any hassels? :oops:
Profile - Cars Owned - AE82 Corolla GT / Corolla Dirt Track Car / N14 Pulsar GTI / S14 Silvia Qs / Nissan Van / Nissan Avenir GT
Current cars - Altezza RS200 and Mitsi Lancer GSR
skoty
Re: 4age + c52
Postby Monsterbishi » Sun Jun 27, 2004 7:32 pm
skoty wrote:Just wondering...
Yes it uses a C52, but with a slightly different shifter setup(they're on the other side of the shifter mounting thingy...
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby AceSniper » Mon Jun 28, 2004 3:05 pm
yea the shifter is around the other way, I read a website awhile ago that showed how to convert a fwd c56 to work in the aw11, was a mix of using the aw11 shifter and drilling the c56(same as c52)
AceSniper
Postby MrOizo » Mon Jun 28, 2004 3:14 pm
AceSniper wrote:yea the shifter is around the other way, I read a website awhile ago that showed how to convert a fwd c56 to work in the aw11, was a mix of using the aw11 shifter and drilling the c56(same as c52)
C56 being the blacktop 5Speed box?
if so its the AW11 SC MANUAL box and th internals pf the C56.
you'll find all the info at www.padandwheels.com/mr2
MrOizo
Toyspeed Legend
Postby AceSniper » Mon Jun 28, 2004 8:58 pm
MrOizo wrote:C56 being the blacktop 5Speed box?
c56 is facelift ae101 and 5speed ae111 (20v) same as a c52 but 3rd and 4th ratio is slightly changed the page I saw the conversion on was upgrading from a worn standard aw11 box to the c56... had full detail.... mite try an find it sum time
AceSniper
Postby skoty » Mon Jun 28, 2004 9:22 pm
Cheers for the info guys :)
skoty
Postby AceSniper » Tue Jun 29, 2004 1:24 pm
AceSniper
