stripped bolts!!!
stripped bolts!!!
Postby 20vtoylevin » Thu Jul 01, 2004 6:28 pm
hey does anyone have any advice on how to get a bolt which has rounded off as i tried to get it off!!!its on the exhaust manifold bearing in mind dont have a welder and cant drive it anywhere!!!
cool thanx guys!!! :?:
blah
20vtoylevin
bolt
Postby JasonZE » Thu Jul 01, 2004 6:32 pm
Hammer a single hex socket onto it if its real bad go for a socket 1mm smaller and bash it on failing that WELDER
JasonZE
Real Life Mechanic
Postby GTUWET » Thu Jul 01, 2004 7:02 pm
tap a new thread???
[GTUWET] AnD lEaViN u DRiPpIn!!
GTUWET
Postby Shotgun » Thu Jul 01, 2004 7:20 pm
Grind or file down 2 sides then use a big shifting spanner.
Shotgun
Postby 2fas4u » Thu Jul 01, 2004 7:20 pm
could try the following:
either hammer a deep cross and try to get it out with a philips screwdriver or enough space is available, drill a hole through the middle of the bolt and shove a steel rod through that hole and turn it out. or get a file and file two sides down parallel and try and get a spanner or cresent wrench and turn it out.
2fas4u
Postby Farmer_dave » Thu Jul 01, 2004 8:58 pm
Bashing a smaller socket on works best.
My Profile:
Now updated with a new pic
http://toyspeed.blakjak.net/profiles/profile.php?id=201
1997 Caldina GT-T
Farmer_dave
Postby Bazda » Thu Jul 01, 2004 11:18 pm
hammer and cold chiesel works well, my mate lost his lock nut key so used a chiesel and it worked mint.
Postby MEX » Fri Jul 02, 2004 1:08 am
been on your exhaust manifold the heat will have jammed it in there real well, so whatever method you use try adding some heat with a gas touch or even a heat run while your trying to turn it :D
Old Toyota's Never Die... They Just Get Phater
http://homepages.e3.net.nz/~bill-mecchia/
MEX
