Handbrake
Handbrake
Postby TruenoBoy » Mon Jul 05, 2004 7:40 pm
Where is the adjustment for the handbrake in an AE101 and what is the correct method of tightening it?
This is for the 4 wheel disc version of AE101.
Sam
TruenoBoy
Postby Silent Knight » Tue Jul 06, 2004 12:53 pm
take out the console and there should be a little screw which you can turn to shorten the handbrake a bit. this will only shorten the distance in which you pull the handbrake.
if you have a luk at your rear wheels just behind the caliper there should be what looks like a butterfly screw or whatever you call it which you can use to tighten the handbrake cable.
Silent Knight
Postby levin_it_large » Tue Jul 06, 2004 3:17 pm
is this the same with an AE111 or is it a different kettle of fish
levin_it_large
Postby Silent Knight » Tue Jul 06, 2004 4:54 pm
it's the same with the 111 :wink: :wink:
Silent Knight
Postby [V8ROLA] » Tue Jul 06, 2004 7:09 pm
as said ANY hnadbrake adjustment should be done on the rear shoes/disk, never on the handbrake itself.
1995 ducati 900ss with a 2001 fuel injected motor, ramflow intake, open pipes, polished wheels and afew other mods.
more to come ;)
1983 RX7 series 2 with small block chevy.
http://photos.data.net.nz/?dir=V6ROLA%2 ... sion%20%2F
[V8ROLA]
Real Life Mechanic
Postby 10k 20v » Tue Jul 06, 2004 8:24 pm
i'll back that.
Never ever adjust the handbrake cable on any vehicle unless it has been previously tightened by someone else.
The correct method on drum brakes is to adjust the rear brakes themselves, as this will also adjust the handbrake.
With disc brakes the cable should only be adjusted to the point when the lever on the caliper sits on its stop and there is minimal slack in the cable.
If this is the case then you will have to remove the calipers from the rear discs. Wind the piston back a few turns, refit calipers and pump brake pedal hard about 20 times. Do NOT pull the handbrake lever untill you have pumped the pedal
10k 20v
Postby Ae92typeX » Tue Jul 06, 2004 8:30 pm
Are they not self adjusting?. My ae92 was (rear disks), & my mate had a mazda with rear drums that self adjusted. I would have thought they were. Sometimes the adjusters get clogged with brake dust & need cleaning with break cleaner or similar.
Ae92typeX
Postby 10k 20v » Tue Jul 06, 2004 8:39 pm
yes they are self adjusting but with everything mechanical nothings perfect
10k 20v
Users browsing this forum: No registered users and 46 guests
