interor paint
interor paint
Postby phatman3801 » Tue Jul 06, 2004 10:28 am
hey im gunna paint my interior soon ( holiday job for the car) jst doing arnd the stero and arnd the air vents etc all plastic oi think, jst woundering if its sweet to use normal spray paint 4 this? should i put a some sort of clear coat over the top as well to stop the paint frm chipping off? ne help would b good cheers!
phatman3801
Postby celica_tommo » Tue Jul 06, 2004 11:36 am
don't do it... it looks like crap and will inevitably start flaking off
celica_tommo
Postby phatman3801 » Tue Jul 06, 2004 1:01 pm
i waznt asking wot it looks like as i have seen heapsa pic of cars with it dne it it looks kool az! im asking wot sort of paint i should use, and weather i should spray a clear coat over it az well?
phatman3801
Postby rollas22 » Tue Jul 06, 2004 1:11 pm
Bro, use a Plastic primer on every bit of plastic you paint. then spray with normal spray paint, then give it to coats of clear coat once all finished!
It comes up mint. I done my whole interior like than and nothing has come off!
plastic primer is about $19.95 per can (get from painters)
then ya spray paint and clear coat
rollas22
Postby phatman3801 » Tue Jul 06, 2004 1:13 pm
hey cheerz for that man, ill give it a go! did u sand the plastic lightly b4 hand as well? or jst start stright out with the plastic primer?
phatman3801
Postby PRYMORTAL » Tue Jul 06, 2004 1:31 pm
light sand with very fine grit sand paper proably wet & dry (Tufbak), or u could use meths to clean it, it melts the plastic slightly so sanding isn't really needed (need to clean it if its had interior silcon cleaner over it b4)
PRYMORTAL
Postby celica_tommo » Tue Jul 06, 2004 7:38 pm
yeah actually that plastic primer would help a lot.... I just sanded mine and used regular primer
remember though that the texture of the surface will show through wether it's rippled or scratched from the sandpaper
I wouldnt recommend doing it cause it's less durable than having it left unpainted
celica_tommo
Postby Ae92typeX » Tue Jul 06, 2004 8:38 pm
If you sand it use fine grade wet n dry likd 600 or 800 grit, all done well it wont show through on your final finish. Def get the plastic primer to- its a lot better than regular stuff for plastics.
Ae92typeX
Postby GTUWET » Tue Jul 06, 2004 10:14 pm
wat bout 4 painting vinyl??
[GTUWET] AnD lEaViN u DRiPpIn!!
GTUWET
Postby Ae92typeX » Tue Jul 06, 2004 10:18 pm
GTUWET wrote:wat bout 4 painting vinyl??
you can get spray made for painting that
Ae92typeX
Postby celica_tommo » Tue Jul 06, 2004 10:46 pm
I tried vinyl paint on my interior first without primer and it flaked off easy as
but yeah... you can get vinyl spray paint from mitre 10
celica_tommo
Postby Ae92typeX » Tue Jul 06, 2004 11:15 pm
I got some vinya paint afew years back that worked like a dye, was really good. However that was on an older car vinyl which was softer than the more plastic stuff now. If you were going to do the whole dash it could pay to ring around some dash restoration/building places as some have good prices to change colour.
Ae92typeX
Postby Andy from the block » Wed Jul 07, 2004 1:15 am
celica_tommo wrote:don't do it... it looks like crap and will inevitably start flaking off
hmm ive been told me interior is pretty good and I like it , but everyone has thier opinions.
Mine hasnt started flaking off and neither has anyone elses I know thats done the same thing.
I didnt even prime the surface , jst cleaned it thoroughly. I used VHT interior paint and it came up sweet. Its a good quality enamel and I didnt need to use a clear coat at all.
Andy from the block
Postby rollas22 » Wed Jul 07, 2004 9:57 am
Vinal Paint, you can get a good brand from your local car painters, but definatly clean the area with hot soapy first. Let it dry, then apply a couple of coats of Plastic primer! Then apply the vinal paint, use a proper airgun for this.
I recomend not sanding any plastic bits, just plastic primer them, it works just as well!
rollas22
Postby MR2boy » Wed Jul 07, 2004 10:11 am
ud probably wanna go get some wax and grease remover and wash whatever ur gonna paint with that to get rid of the crap u put on to keep it shiney (that should stop fish eye)
then i would keep sanding to 600 or even 400 for primer, u want it to stick then use 600-800 to sand the primer ready for the top coats
MR2boy
Postby boyracer69 » Wed Jul 07, 2004 11:13 am
I sanded with hell fine sandpaper as to get rip of the textured look thats on most the plastic pieces. Then use a plastic primer. Mine came out mint and have had no probs. :)
boyracer69
Postby Deno » Wed Jul 07, 2004 7:36 pm
If you go to your local spray paint supply store (automotive), they should have a 3 piece kit that works great. The primer, colour of your choice, and a clear laquer.
Spray store in Chch have them.
You're just jealous the voices are talking to me!
85 MR2 NA faded red
86 MR2 Supercharged
90 Starlet GT (sold)
93 AE101 Levin parts car (PM if you need anything!)
97 Carib Sprinter (sold)
Deno
Postby GTUWET » Wed Jul 07, 2004 10:11 pm
wat can u use 2 paint the fabric on door trims without using a dye
GTUWET
Postby boyracer69 » Thu Jul 08, 2004 4:41 pm
Your best off to retrim the fabric bro. Take yah doors off, rip the old farbric off (carefully) as you want to use that as the outline for your new fabric. Place the old trim on your new fabric and cut out the same shape. The best glue i found was ados spraycan glue, works a dream. I did the trim in 1/2s. So spray one side of the trim you are doing and lay that down and smooth it out, then spray the other half and smoothen it out.
If thats wot yah meaning i think ya would be way better off doing new trim and its pretty easy.
boyracer69
