7AFE issues!!!
7AFE issues!!!
Postby [TWZTID] » Fri Jul 09, 2004 11:55 pm
Ok, so I have a 1996 Caldina with a 7afe(2WD). Unlike what it says in the 'sticky' to the site that has info on toyota engines, mine is a single cam engine, twin electric? distributers & a long J shapped throttle bottle if you look at it from side on.
My mate pulls up in a 1997 Carib 4WD with a 7afe, 'normal' looking distributer, & a roughly looking 4age throttle bodie (I saw it outside with not much light). Mine red lines at 6, his a little after 6. The power/speed felt kinda the same. Why are they different?
[TWZTID]
Postby NZ_AE86 » Sat Jul 10, 2004 12:04 am
Dude, if it is a 7AFE then it is a twin cam, the engines could be different for alot of reasons. As you have stated, different year or maybe assembled in a different country, could be because it is 4WD.
NZ_AE86
um...
Postby [TWZTID] » Sun Jul 11, 2004 2:13 pm
4WD would explain his, makes sense.
When I sober up some more I'll go & get my car & find that 2nd cam :D
[TWZTID]
Postby spencer » Mon Jul 12, 2004 11:00 am
maybe your confused with the single pulley twin cam head used on those narrow angle fe heads??
ms63 crown
spencer
Postby Mr Revhead » Mon Jul 12, 2004 2:05 pm
also 7afes come with dizzy OR muti coil set up...
so they are different because they are different :D
Users browsing this forum: Google [Bot] and 26 guests
