4AGZE - 4AGTE
4AGZE - 4AGTE
Postby 4AGTE » Sun Jul 11, 2004 9:00 pm
If you were doing 4AGZE to a 4AGTE using the Generation 3 link coming out in October what turbo and manifolds would you use?
Also things that might be problems?
Just need the knowledge to get the most out of this conversion.
Wanting 200kw at the wheels if possible!
Motor is an AE101.
This question has proble been asked heaps so soz in advance for that.
Thanks
4AGTE
Re: 4AGZE - 4AGTE
Postby Lloyd » Sun Jul 11, 2004 11:20 pm
4AGTE wrote:This question has proble been asked heaps so soz in advance for that.
Indeed it has. Have a search on here for "4AGTE" and see what you get. Search the web for a bit too and ask some specific questions if there is something not clear.
As far as manifolds go, get an exhaust manifold made up which you should be able to get done all over the place and for an inlet manifold the 100kW redtops are the popular choice. Theres one for sale in the FS section on here with throttle body for $100 which would be about what you're after (assuming its not the TVIS one)
Re: 4AGZE - 4AGTE
Postby EVLGTZ » Mon Jul 12, 2004 7:34 pm
$100 is good price for the intake manifold, do well to find nontvis redtop one at that price.
As for turbos and manifolds it all comes down to what ya want out of ya car as this will drive the turbo choice. Popular ones are the T25, T28, T3/4 and TD04, TD05h etc or if got the $$ go ball bearing.
I've seen all these on 4AGTE setups and all work well but all give a very different car to drive. Once you sort what turbo ya want, then get manifold made to suit. Plenty of people making good quality ones for pretty cheap nowdays, try Action Dan on here, he does some pretty good ones.
200KW at the wheels should be doable without too much trouble.
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby 4ageturbs » Fri Jul 16, 2004 8:52 pm
I rekon save yourself 500$ and use a standard 4age exhaust manifold, chop it and weld on a plate they flow good enough as they are a n/a manifold mine cost me 80$ to make, i have a intake manifold if your interestd, is your engine an old or new model ze?
4ageturbs
Postby EVLGTZ » Sat Jul 17, 2004 12:41 pm
4ageturbs wrote:use a standard 4age exhaust manifold, chop it and weld on a plate they flow good enough
$&#$% that :lol:
EVLGTZ
EVLGTZ
Postby VTEXTC » Sat Jul 17, 2004 6:19 pm
f**k that :lol:
I 2nd that.. chopping anything is a bad idea.
VTEXTC
Postby 4ageturbs » Sat Jul 17, 2004 7:08 pm
Whats bad about it, and how do you know that your custom 1 will be much beter, Ive ran 18psi 4 1 year it even glows red and it hasnt cracked, the diference would be what??? maybe a litle more top end 10hp if your lucky thats worth 500$
4ageturbs
