4agze finally going to go?
Postby gtz666 » Wed Jul 14, 2004 7:27 pm
hey my ae92 gtz afm is being really wierd 1/4 throttle it's sweet then you put your foot down and it misfires or something (coughs and farts) then it comes right and takes off then sometimes it bogs down it happens at any rpm normal temp etc doesn't happen all the time but seems to happen more often now......ideas :?
gtz666
Postby lost » Wed Jul 14, 2004 7:49 pm
This is a stupid question, but its solved this prob on a car of mine before. You made sure ur air filter is sweet and completely intact (if uve got a pod make sure its still attached to the metal, yes, they come apart and cause this lol) and that there's nothing limiting the supply of clean air to the engine? Correct me if I'm wrong but I dont think there's vac tubes to worry about on the intake side of an AFM GZE? In which case its likely to be the AFM, which are a semi common thing to go bung
Octopus Thingy~!
lost
Postby Kender » Wed Jul 14, 2004 7:55 pm
Sounds like an ignition problem. Check the plugs and leads, and clean out the distributor cap and rotor.
'84 AW11 SC racecar "RDDWRF"
'92 SW20 GT-S
'91 GT Legacy wagon
Kender
Postby gtz666 » Wed Jul 14, 2004 7:56 pm
hmm never thought of something simple i'll have to check it ou thanx :)
oh anyone know how you check the afm i presume with a multimeter but dunno exactly where you need to check
checked plugs and leads all sweet and has ignition pack thing dunno how to check that either
gtz666
Postby AE85.6 » Thu Jul 15, 2004 12:00 am
mates turbo silvia did the same thing dude, can be if water has got to the AFM, his was at the panel shop and the silly pricks left it outside with no bonnet, course it rained causeing the problem, aparently you can take the AFM out and spray/soak it in that crc electrical contact cleaner (the real cold stuff that evaporates quick) cleans them out of crap and it ran like new
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby gtz666 » Thu Jul 15, 2004 3:11 am
sweet i'll give that a go today and see what happens and post it
gtz666
Postby AE85.6 » Fri Jul 16, 2004 2:23 pm
help at all ??? only other thing o thought of was something with ignition as has been said
AE85.6
Postby gtz666 » Fri Jul 16, 2004 7:10 pm
:) popped open the afm and looked sweet but still sprayed some of that contact cleaner on it and sealed it back up and went for a lil drive no problems and went for another lil drive today still no problems so seems to of worked
:)thank you everyone :)
gtz666
Postby AE85.6 » Sat Jul 17, 2004 5:07 pm
sweet hopefully that was it
AE85.6
Postby wanado13's » Sat Jul 17, 2004 6:47 pm
Hey can any one help me my car does the same sort of thing except it's a map sensored ae92 gtz and it makes those sorts of noises every time i try to give it some gas.
wanado13's
Postby AE85.6 » Sun Jul 18, 2004 1:47 pm
as said before i think it could be an ignition problem ?
AE85.6
Postby wanado13's » Sun Jul 18, 2004 5:39 pm
yea im going to go get it checked out but i didn't think it would be that because it's the supercharger that makes the squeking noise.
wanado13's
Postby wanado13's » Mon Jul 19, 2004 7:51 pm
supercharger clutch is fried! got it checked out
wanado13's
Users browsing this forum: Google [Bot] and 17 guests
