Stealer Of Souls wrote:Hey all...
Long time ago I was asking this question... And it's reared it's head again.
I've just finished installing a new combo gauge thingy which has and AFR reading on it. After tracking down the EGO sensor wire and connecting to it I fired up the gauge...
And no AFR reading... Or more exactly, it was off the bottom of the scale.
I have only run the car for about five minutes, as it was getting late and I had a long list of other stuff I had to finish. Is this my problem? Do i need to take the car for a good drive first?
Also, I've had the car on the dyno and the AFR was fine, so I'm assuming it's still okay since nothing has gone wrong.
Redmist mentioned checking the engine codes. How? What should i see? It may be a moot point since I don't know if my check light actually works...
The sensor is there. The gauge does it anyway... I just want the pretty lights to go up and down because they are there and they're supposed to.strx7 wrote:factory type narrow band oxygen sensors suck and you were wasting time and money even connecting a guage to it. if you want AFR's which are of any use what-so-ever you need a wideband 5 wire sensor and the appropriate guage/meter to go with it
