Caldina gearbox into ST165??
Postby hoolio » Sat Jul 17, 2004 2:39 pm
I have no model numbers which is mighty useless for this post , but does ant one know if a 1996 Caldina 5spd gearbox will fit an ST165 3SGTE??
Any info appreciated.
hoolio
Postby Hotgt4 » Sat Jul 17, 2004 3:56 pm
If you got the ST215 3s-gte engine to go with it, it would well be worth the time. You are talking about a manual 'box from a caldina NA or Turbo?
GT4- Heavy lug of a car that could plough a road to china.
Hotgt4
Postby dodgy » Sat Jul 17, 2004 5:37 pm
sould do.. i got my caldina 3sge to fit my mr2 gbox.
dodgy
Postby Malcolm » Sat Jul 17, 2004 6:02 pm
it should fit, although if it's from an NA caldina it may not be as strong. Do you know the gearbox code?
Postby Twolitre » Sun Jul 18, 2004 7:42 pm
Why not just try to find an ST205 box? It bolts straight in using your existing ST165 mounts and is a strong box with tripple and dual cone synchros on 2nd and 3rd with the same final drive as your gearbox.
Twolitre
Postby hoolio » Mon Jul 19, 2004 11:13 am
Yes the ST205 box is the best option if I can find one!
& better to know that it will work & mate up sweet.
hoolio
