ae86 rear shocks
ae86 rear shocks
Postby spencer » Tue Jul 20, 2004 11:39 am
What shocks from other models of cars will fit but are shorter in the rear?I got some new springs and need some shocks to make it captive to get a wof unitl I can afford decent adjustables
ms63 crown
spencer
Postby 86 Power » Tue Jul 20, 2004 1:15 pm
You can get a short stroke shock from either:
Toyota Corona Mark II station wagon KYB (firm ride)
Toyota Hilux KYB (Very firm) not sure if you use front or rear?
If you want adjustable, buy both for half the price of TRD and just swap them when you race / drift / whatever :)
86 Power
Postby fangsport » Tue Jul 20, 2004 6:46 pm
KE36 wagon shocks are good for pulling the arse end down, possibly a bit on the soft side but a heavy duty replacement is probably available.
fangsport
Postby AE85.6 » Tue Jul 20, 2004 8:43 pm
pretty sure garage dori had a link to all different toyota model cars that had the same shox and what lengths they are shortened by
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby gdsup » Tue Jul 20, 2004 9:23 pm
gdsup
Postby gdsup » Tue Jul 20, 2004 9:26 pm
gdsup
Postby JT » Tue Jul 20, 2004 10:56 pm
After reading that it seems the AE92 front shock would be a good replacement combined with a low spring in an AE86
I'm pretty sure mine has standard shocks and with the current springs in it they are bordering on the limit of being captive when jacked up. I'd like to go lower too but don't really have the money to go height adjustable. The only thing is will how good the standard shocks will put up with a reasonably firm spring :?
JT
Postby spencer » Wed Jul 21, 2004 9:22 pm
Had some newish ke36 jobs sitting at home so slapped them in for a warrent they shortened it up quite abit. For the fornt found out my g/f gets good deals from that stocks place from her work repco. So ordered my sleve and stuff for my car threw her worked out less than $80 a side without a spring
ms63 crown
spencer
Re: ae86 rear shocks
Postby matt dunn » Thu Jul 22, 2004 12:37 am
ke70wagon20v wrote:What shocks from other models of cars will fit but are shorter in the rear?I got some new springs and need some shocks to make it captive to get a wof unitl I can afford decent adjustables
KE70 corolla wagon will bolt right in and are shorter cause of the lower floor.
