Help, I need an Altezza ECU (3sge Beams Tiptronic)
Postby Dimon » Mon Jul 26, 2004 1:01 am
Hi Guys ,
I have previously posted about my Altezza going to Limp/Failsafe mode upon starting up the car. The suspected problem at the time was fly-by-wire system in the throttle/throttle position sensor. After performing numerous checks, all the sensors and throttle motor checked out fine.
I proceeded to examine the ECU, and it appears that someone has performed some soldering on it.
As I am rapidly running out of things to test, I would really appreciate if somebody got a spare working ECU, let me know about it.
Any feedback on this matter is wellcome :D
Dimon
Postby Al » Mon Jul 26, 2004 1:03 am
send a pm to turbo tezza he has a whole spare motor and other bits incl tiptronic ecu for beams 3sge
8)
Al
Postby Dimon » Mon Jul 26, 2004 1:27 am
Wow that was fast 8O
Cheers dude :wink:
Dimon
Postby TWSTD » Mon Jul 26, 2004 4:14 pm
That car has had a replacement ECU in it and that did not fix the problem (so im told). The soldering was done by an ECU repair place in an attempt to fix the ECU - whether there was nothing wrong with it or they fixed it I have no idea!
Click here!
TWSTD
Postby Dimon » Tue Jul 27, 2004 10:43 pm
That helps alot :roll:
I guess I'll try the new ECU anyway, so if anyone else has got one, please let me know :wink:
Dimon
Postby Tezza » Wed Jul 28, 2004 5:33 am
Muzza
Tezza
altezza ecu
Postby Celica RA45 » Wed Jul 28, 2004 2:23 pm
i have a manual beams altezza ecu for sale 500 aussie plus postage if that will help you out
Celica RA45
Postby Dimon » Tue Aug 03, 2004 11:13 am
Put in new ECU, problem FIXED !!! 8)
Woohoo thanks for your help guys
Dimon
Dimon
Postby turbo tezza » Tue Aug 03, 2004 6:35 pm
No worries :)
Glad i could help :wink:
Corey
turbo tezza
