what kinda hp would this be making. . .?
Postby Banga69 » Thu Jul 29, 2004 2:54 pm
evo 0
extras
evo2 engine
standard tdo5h turbo
huge front mount
gizzmo
5 zigen muffler
running 12psi
than later adding
38 mm wastgate
T3/04 turbo
3" mandrel zaust from turbo
running 12psi
CURRENT:
1994 Mazda Lantis
EX:
SOLD: AE101 GTZ ====>http://toyspeed.blakjak.net/profiles/profile.php?id=89
Banga69
Postby EVLGTZ » Thu Jul 29, 2004 3:00 pm
very hard to say. Someone on nzmmc might be able to hazard an accurate guess. but maybe around 350hp at the engine?
So hard to say as all depends on tuning etc.
Also wonder why somone would only run 12psi on the to4 when could easily run 18psi on the std turbo or t04 etc
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby Banga69 » Thu Jul 29, 2004 3:02 pm
EVLGTZ wrote:very hard to say. Someone on nzmmc might be able to hazard an accurate guess. but maybe around 350hp at the engine?
hes planning on running a fair amount more, im just trying to campare the standard mods now to the mods hes going to fit later.
CURRENT:
1994 Mazda Lantis
EX:
Banga69
Postby badidas » Thu Jul 29, 2004 4:25 pm
im not positive but i thought the evo zero engine crank/rods/pistions were stronger or as strong as that of the evo items?
1989 mazda bongo aka [BNGBUS]
badidas
Postby Monsterbishi » Thu Jul 29, 2004 5:43 pm
badidas wrote:im not positive but i thought the evo zero engine crank/rods/pistions were stronger or as strong as that of the evo items?
The E0 engine is identical to a standard VR4 engine, with the sole exception that it's camshafts are identical that what's in the E3.
Strength wise the 6bolt VR4 motor leaves a 7 bolt Evo motor for dead...
Which is why VR4 rods are so sought after...
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby blackie » Mon Aug 02, 2004 11:34 pm
isnt the fact its an E0 irrelevant - it says E2 motor..
prob not much more than stock.. i dunno what they run factory but it must be close to 12psi already.
maybe 300-320hp@fly
and if after those mods its still running only 12psi, wont it just make the same power as before.. except maybe spool up faster and get that power quicker or something.
blackie
Postby Al » Tue Aug 03, 2004 5:42 am
blackie wrote:and if after those mods its still running only 12psi, wont it just make the same power as before.. except maybe spool up faster and get that power quicker or something.
errr no because psi is just a measure of pressure....not of actual air moved through the turbo and into the engine 8)
Al
Postby Rollux » Wed Aug 04, 2004 1:38 pm
With a larger turbo the efficiency is better, hence the cooler the intake charge and hence the more oxygen dense the air is. BTW, will that T3/04 be in its efficiency range at 12psi? I would have thought you would want to run at least 1bar to get it up near peak efficiency.
2002 Allex RS180 6 Speed
Racing a Honda is like competing in the Special Olympics. Even if you win, you are still a Retard.
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Oversteer is when the Passenger is scared. Understeer is when the Driver is scared
Rollux
