AIR CONDITIONING PROBLEMS
Postby B1NZ » Tue Aug 03, 2004 8:36 pm
Hello and good morning/afternoon/evening (delete which doesnt apply)
The gf has a 1991 Cynos in which the air cond was working last summer, then all of sudden it doesnt go, the light comes on when the button is depressed with the fan going but it doesnt seem to click in and the revs drop slightly when idleing, What the deal? Anyfuses to check? Whats the most common problem? Where do i start looking?
Cheers Brendon
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby GTUWET » Tue Aug 03, 2004 9:25 pm
revs will always drop in all cars just the thing it does, just rip the lot out and wind the window down 8)
[GTUWET] AnD lEaViN u DRiPpIn!!
GTUWET
Postby Adamal » Tue Aug 03, 2004 10:14 pm
Leaking gas maybe?
Postby B1NZ » Wed Aug 04, 2004 8:37 am
GTUWET wrote:revs will always drop in all cars just the thing it does, just rip the lot out and wind the window down 8)
nah, what i meant was it used to drop the revs when the aircond was switched on, but now it doesnt.
Would that indicate that the aircond unit clutch or whatever is not engaging?
Subaru GF8 Wagon
B1NZ
Postby MrBob » Wed Aug 04, 2004 9:37 am
B1NZ wrote:nah, what i meant was it used to drop the revs when the aircond was switched on, but now it doesnt.
it'll just be outta gas. The unit wont cycle / engage if outta gas, hence revs wont drop. I have had to degas my aircon several times recently, and once degased it dosent cycle anymore. Will cost you about 60 - 100 dollar to get it refilled
MrBob
Postby rollas22 » Wed Aug 04, 2004 9:47 am
remove it
rollas22
Postby thaphatty » Wed Aug 04, 2004 12:07 pm
why remove it? its a freakin cynos :roll:
thaphatty
Postby rollas22 » Wed Aug 04, 2004 1:58 pm
add a little more hp, but not much....
rollas22
Postby MrBob » Wed Aug 04, 2004 3:02 pm
rollas22 wrote:add a little more hp, but not much....
*news flash* removing aircon does not increase hp of your engine. It will reduce resistance on your engine... or you can simply switch it off, which has the same effect. Its is generally removed to reduce weight.
As has been pointed out, its a cynos...if you must drive a cynos you may as well have the cumfort of aircon.
MrBob
Postby WALT3R » Sun Aug 08, 2004 6:37 pm
Mr bob is onto it, open the bonnet, look were the release latch is at the front between the headlights, there is like a air valve there, thats what they fill it with, i wouldnt mess with it yourself, take it to an expert. check your belt is tight too, might be loose as a nuns bum... gud luck
Why do babies shit themselves?.... sometimes you just dont know any better
WALT3R
