Silvertop Rebuild
Silvertop Rebuild
Postby Sanxta » Sat Aug 07, 2004 2:14 pm
Hi, I need to get a rough cost replacing standard parts (rings and whatever else wears out significantly faster than the rest of the engine) and a port and polish for the 4AGE SIlvertop 20 Valve engine.
This is for a STANDARD rebuild I am not putting racing parts in just want to know from people who have done this what it cost you in terms of parts, labour, or all up, whatever, I just need a basic idea at this stage.
Chur,
Adam
Sanxta
Rebuild
Postby CAMB01 » Sat Aug 07, 2004 10:08 pm
Well, it really depends on where you take the motor. If you take the motor out of the car, your looking at around about $2000 - $3000 for the complete rebuild, thats stripping, measuring, machining, rebuilding, parts and labour.
CAMB01
Postby Sanxta » Sun Aug 08, 2004 7:08 pm
Cheers, how much labour would be involved for putting in a new piston set (TRD[?]) ?
Sanxta
Postby Mr Revhead » Mon Aug 09, 2004 9:39 am
i can do new pistons from around $75-80 each.
pm me with a list if you want specifc prices
Postby Sanxta » Thu Aug 12, 2004 4:02 pm
Cheers, is that the standard toyota new price?
Thanks,
Adam
Sanxta
Postby pplmvr » Thu Aug 12, 2004 4:11 pm
sounds like you gonna put some real performance in there etc..
Big Is Good & Its Great to Play Together
2+3+3 = Great FUN~!
pplmvr
Regular Poster
Postby Sanxta » Thu Aug 12, 2004 4:16 pm
if that was sarcastic then cheers for your useful input
Sanxta
Postby JT » Thu Aug 12, 2004 4:52 pm
pplmvr wrote:sounds like you gonna put some real performance in there etc..
Dude, whats up with your posts? There's a quote "If you can't dazzle them with brilliance, baffle them with BS". Sounds like you've adopted this as your moto :roll:
Sanxta, if you only want a standard rebuild and aren't wanting any performance parts, a second hand engine would be the cheapest option IMO. You have no reason for putting higher spec pistons in unless you want to run higher revs or go FI.
JT
Postby Sanxta » Sat Aug 14, 2004 4:07 pm
Yeah, that's hardout what I was thinking too.
But you can never be sure of the KM's that the importer SAYS it has done, that would be my big worry.
Plus that seciong hand engine still has wear on it, whereas a rebuilld is all new parts. $1500 silvertop installed in Auckland (forget where).
Hmm . . . I dunno what I'm gonna do cheers for the help tho :P
Sanxta
