adjusting clutch
adjusting clutch
Postby minijrocks » Mon Aug 09, 2004 5:54 pm
Hi, i have a 91 trueno apex blah blah, and ive just got it and it has a new clutch.
Can i adjust when the clutch engages? At the moment its kinda annoying because it doesn't engage until its pretty much right out and i want to move it to about half. Where can i take it to get this done (if i can) on the north shore and how much . cheers. also when does your clutch engage?
minijrocks
Postby badidas » Mon Aug 09, 2004 6:07 pm
hey dude sounds as if the fluid level is low or the clutch master or slave cylider is ferked because they are hydrolic and have no way to adjust them
i can do the work cheeply and/or have a look at it might even have the parts at home
im on the north shore pm me if your keen kay
peace
1989 mazda bongo aka [BNGBUS]
badidas
Postby starlet » Mon Aug 09, 2004 10:28 pm
You can adjust the pedal engagement slitly.
Look up under the dash where clutch pedal goes and ull see a locking nut.
loosen nut and twist rod that goes into clutch master cylinder, twist it one way then try driving to see where clutch works at, then twist other way till u get desired place.
Dodgy but works.
starlet
Postby Ae92typeX » Tue Aug 10, 2004 12:49 am
Another option for adjusting a hydrolic clutch is make up a new arm from the slave cylinder to clutch fork.
It all depends on the setup wether it would work or not though.
Ae92typeX
Postby minijrocks » Tue Aug 10, 2004 6:38 pm
its not that bad, its just different, just needed some getting used to.
minijrocks
