hey i was just wondering if anyone knows if you can use an ae85/7 X member to mount the engine like the later KE70's? or do custom mounts have to be made?
cheers. Sam
MetalupYoAss wrote:hey i was just wondering if anyone knows if you can use an ae85/7 X member to mount the engine like the later KE70's? or do custom mounts have to be made?
cheers. Sam
purple_beasty wrote:The AE86 has rack and pinion, the KE30 has a steering box. And the crossmember won't bolt in either. Easiest just to get engine mounts made to suit the k series crossmember.
Callum
