TVIS seems to be stuck on :S help??
Postby RollaGT_87 » Thu Aug 12, 2004 7:04 pm
My AE82 is real laggy down low, cupla mates rekon TVIS is stuck on. trouble is, i dunno if the TVIS manifold is even THERE :x Any help would b greatly appreciated. Diagrams, pictures, explanations, anything you can think of to do with TVIS.
Tip for successfull rally driving: Don't sink you're car in the first pond to catch your eye.
"That's a f**kin' b*gg*r innit??"
"We were a bit hot, thought we'd take a dip n cool off"
RollaGT_87
Postby badidas » Thu Aug 12, 2004 7:56 pm
doubt its jammed on more than likley have something to do with the small plastic vacuum tank or solenoid triggered diaphragm actuator under the inlet manifold that is if its even a problem with tvis at all ?
you could pull the intake manifold off the car and check operation of the
butterflys make sure there still there and someone hasnt removed them
more than likely they would unplug it than pull the butterflys out
has it always been like this or has it just started to happen ?
1989 mazda bongo aka [BNGBUS]
badidas
Postby kingcorolla » Thu Aug 12, 2004 9:17 pm
the TVIS is like the little 1 inch manifold between the head and the manifold.
click my profile below for a pic
when i stripped it te butterflys dont wanna move in a hurry when i push them manually so MINE mite be stuck on aswell
1983 Carina AA63 4age
kingcorolla
Postby EVLGTZ » Thu Aug 12, 2004 10:00 pm
yeah, prob find someones removed the butterflies from ya tvis
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby EVL-EP8U » Fri Aug 13, 2004 2:28 pm
Hi coran its mike,
prolly have to rip the intake mani
off and check as these ppl have said.
Also whats some tvis butterflies worth??
ep82= bent
Gx61 mark II Highway Dancer
Garage Slipway
Now 1ggte'd
EVL-EP8U
Postby ants_ae92 » Fri Aug 13, 2004 8:43 pm
I'd say the assumption of the tvis stuck on would be correct.
There should be a vacuum hose that goes to a plate in between the intake manifold and the head. See if its attached. If its not the tvis would not open at all.
ants_ae92
Postby kingcorolla » Fri Aug 13, 2004 10:02 pm
might as well kill 2 birds with one topic,
i took my manifold/TVIS off and the butterflys are real stiff, they have some carbon, and some oil deposits from the PCV, but do they stiffen up after a while?Are they ment to be stiff, or should they rotate freely when activated manually?
kingcorolla
Postby Ae92typeX » Sat Aug 14, 2004 1:26 am
what do you mean by freely, they are spring loaded arnt they?, they are in my 1ggte at least
Ae92typeX
Re: TVIS seems to be stuck on :S help??
Postby kingcorolla » Sat Aug 14, 2004 1:29 am
i take that back guys...
i just went out before and spayed CRC on the butterflys and linkages, and worked it back & forth...free it up nicely!!
it was pretty damn stiff tho..
RollaGT_87 wrote:My AE82 is real laggy down low, cupla mates rekon TVIS is stuck on. trouble is, i dunno if the TVIS manifold is even THERE :x Any help would b greatly appreciated. Diagrams, pictures, explanations, anything you can think of to do with TVIS.
this COULD be ure problem? mines an AE82 bluetop aswell.
kingcorolla
Postby kingcorolla » Sat Aug 14, 2004 1:39 am
Ae92typeX wrote:what do you mean by freely, they are spring loaded arnt they?, they are in my 1ggte at least
i meen "freely" like when u push butterflys with ure fingers, they move. Mines vaccuum activated im pretty sure, its got a vaccuum diaphram on it and when i suck on the tube, the butterflys shut but when i stop sucking they open nicely, Before they wouldnt even MOVE!! 8O
kingcorolla
Postby Malcolm » Sun Aug 15, 2004 7:24 pm
t-vis uses a small vacuum plenum and a normally closed solenoid to control switching. The default position is for the butterflies to be open. When you turn your car on the ecu opens the solenoid, allowing the vacuum in the small vacuum plenum (which is fed by the intake manifold), to pull a diaphram which has an arm which is connected to the t-vis butterflies and opens them similarly to a throttle butterfly. So, there are a few possibilities. The solenoid could be unplugged or broken. There could be a leak in the lines, the vacuum plenum, or the diaphram. Or, as has been mentioned, they could just be so gunked up and the springs so stiff that they wont open. I would check that the solenoid is plugged in (it's behind the intake manifold), check that the lines are all connected, check the hoses etc for leaks, and then spray some CRC (maybe use a long thin tube to get it down the intake manifold), and if it still doesn't work then try taking the whole manifold off and investigating further.
Having said that the bluetop 4age isn't incredibly torquey at low revs anyway, so they might be working fine
Postby RollaGT_87 » Tue Aug 17, 2004 12:56 am
Cheers fellas, i'll check that this weekend if i get time... mike, uve got tools rite? we can do my brake pads too :D
RollaGT_87
