Dumb Ass
Dumb Ass
Postby CAMB01 » Thu Aug 12, 2004 11:01 pm
hi just wondering if anyone knows which way Conrods are supposed to go on the pistons, which side does the oil hole on the rod go on.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby thaphatty » Thu Aug 12, 2004 11:09 pm
oil hole as in oil squirter? the thrust side of the bore, should be able to work things out easily enough from there
thaphatty
Postby rollas22 » Fri Aug 13, 2004 5:51 pm
Mine where numbered with arrows pointing towards the front of the engine... this may help.
KE-Corolla's for life!!!
rollas22
Postby Spannergal » Sun Aug 15, 2004 3:33 pm
probably doesn't help now, but i've always found that marking them in someway before removal from the engine helps
Spannergal
Postby solberg Fan » Mon Aug 16, 2004 11:44 am
If its not a honda (i think they rotate anti clockwise?) The thrust side is on the left, looking at the front of the car, from the front.
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
Before you judge someone, you should walk a mile in their shoes. That way, when you judge them, you're a mile away and you have their shoes.
solberg Fan
