mounting a front mount intercooler
Postby 93starletgt » Fri Aug 20, 2004 11:09 am
can anybody give me some advise on mounting
a vr4 intercooler into my GT Starlet. i have already
removed the air con radiator and pump aswell as all its piping 8)
93starletgt
Postby Rollux » Fri Aug 20, 2004 1:44 pm
Easy as. I made some brackets up out of alloy (bent into a sort of Z shape) and bolted them to the lower radiator support panel. Cut the centre support off just above half way down and bolt another bracket to this. From memory there is a centre bracket on a VR4 IC that sits about the right spot for this.
Cut your factory number plate backing out of the front bumper and off set the plate. Mesh for that "i've got a fancy front mount" look!
2002 Allex RS180 6 Speed
Racing a Honda is like competing in the Special Olympics. Even if you win, you are still a Retard.
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Oversteer is when the Passenger is scared. Understeer is when the Driver is scared
Rollux
