Rev counter output conversion...new system to old gauge
Postby ~SlideWays~ » Tue Aug 24, 2004 4:42 pm
Umm dunno if that made any sense but heres the problem
My ae86 has a digital dash display, the rev counter used to run off the standard ignition system of the bluetop but now the car has a map quad coil 4agze so the rev counter wont read right.
It isnt actually plugged in but apparently it would read half the rev's that it should.
So what i need is something to convert the signal so my rev counter will read right....does anybody get what im on about??
I remember being told that there is a mitsi part that can do this, but what from i dont know.
Any help would be appreciated, Thanks
~SlideWays~
interface
Postby ezy10s » Tue Aug 24, 2004 5:24 pm
yes there is a tacho interface available from some mitsi's, it is very easy to install as it only has 3(?) wires.
an input wire for each of the coils and and output wire which runs to your tacho. thats it.
if you get stuck i have a spare here for $30
Member #244
ezy10s
Re: interface
Postby ~SlideWays~ » Wed Aug 25, 2004 1:00 am
ezy10s wrote:yes there is a tacho interface available from some mitsi's, it is very easy to install as it only has 3(?) wires.
What model mitsi did you get the interface from?
Thanks :D
~SlideWays~
rev counter
Postby GOLDAE86 » Wed Aug 25, 2004 1:29 pm
Any 4 cylinder vehicle with twin coils.
To finish first, first you must finish
GOLDAE86
Real Life Mechanic
Re: rev counter
Postby ~SlideWays~ » Wed Aug 25, 2004 4:10 pm
GOLDAE86 wrote:Any 4 cylinder vehicle with twin coils.
off to pick a part then...
oh and where abouts would this magic interface most likely be located or is it really obvious? (im not really in the know with electronics unfortunetly. NZ_AE86 did my loom, it looked like spagetti to me)
~SlideWays~
REv counter
Postby GOLDAE86 » Wed Aug 25, 2004 10:02 pm
The twin coils are located between the inlet manifold and the rocker cover, they are bolted to the inlet manifold, so if the H/T leads are still there just follow them. Failing that myself and NZ_AE86 have lots of them from pic a part.
GOLDAE86
Real Life Mechanic
REv counter
Postby GOLDAE86 » Wed Aug 25, 2004 10:03 pm
GOLDAE86
Real Life Mechanic
REv counter
GOLDAE86
Real Life Mechanic
oops
Postby GOLDAE86 » Wed Aug 25, 2004 10:10 pm
Ooops :D
GOLDAE86
Real Life Mechanic
Postby ~SlideWays~ » Thu Aug 26, 2004 1:24 am
Do i really have to do it three times?
Lol cheers, i'll go have a look at some mitsi's when its not raining. 8)
~SlideWays~
