Cough
Cough
Postby CAMB01 » Sun Aug 29, 2004 10:56 pm
Can anyone please help me?
My car coughs and splutters when i start it cold, then the auto choke comes in. When i drive off when its still cold the engine hesitates and coughs, i put my foot down and nothing happens, it splutters its way up the revs then at about 3500 RPM it comes right. The engine is totally fine when it reaches operating temp, no worries at all.
Any information would be greatful thanx.
P.S. its a redtop big port 4AGE.
CAMB01
Postby Ae92typeX » Sun Aug 29, 2004 11:56 pm
Do you give it anytime to warm up before ya move off?. Changed the plugs any time?
Ae92typeX
Postby Muzzie » Mon Aug 30, 2004 12:53 am
Common place in carbed motors.
My cresta did it, my hiace does it, and the panelbeaters loan car does it too. I think it's just carb icing or similar? Not sure, i've always ignored it, don't have too many problems with it usually because i leave it idling for 30 seconds while I close the gates before I leave in the morning so it's warm enough before it gets onto the road.
Muzzie
Regular Poster
Postby Al » Mon Aug 30, 2004 12:55 am
the car in question being injected 8)
Al
COUGH
Postby CAMB01 » Mon Aug 30, 2004 9:31 pm
Thank you for pointing that out Al.
I Have new platinum plugs in it, leads are ok cap is ok.
I do have a problem with an oil leak, have learned this is a common problem. Oil leaking into the distributor coz the rotor shaft seal has given up due to age. Wondering if the oil getting inside the dizzy is causing a problem. Does anyone know how to fix this problem other than getting a new dizzy or second hand one.
CAMB01
Postby Muzzie » Mon Aug 30, 2004 9:34 pm
Al wrote:the car in question being injected 8)
Sowwie - I didn't know that, I'm trying to learn stuff like that :) And the original poster didn't mention if it was Carb or EFi.
Muzzie
Regular Poster
Postby sixspeeder » Tue Aug 31, 2004 10:04 am
meh
sixspeeder
Bickering
Postby CAMB01 » Tue Aug 31, 2004 9:06 pm
While you guys are bickering over what i posted, i still havn't had any information about what my problem is, sorry to be a bit of a grump i don't mean to be.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby DFECTED » Wed Sep 01, 2004 8:40 pm
Maybe the cold start injector isn't working.
DFECTED
Postby fatgtr » Wed Sep 01, 2004 8:55 pm
or its could be just coz of its age it takes a while to get going. mine does it some mornings (those cold wellington mornings) but let it warm up and it bobs your uncle
James
gotta love the punk music
fatgtr
Postby matt dunn » Wed Sep 01, 2004 9:01 pm
DFECTED wrote:Maybe the cold start injector isn't working.
Once you let the key go from start back to on the cold start injector does nothing so that will not be the problem.
It's a cold start injector not a cold run injector.
My bet would be temp sensor or temp sensor wiring.
Unplug it plug it back on and give it a wriggle.
Matt
COUGH
Postby CAMB01 » Wed Sep 01, 2004 9:04 pm
The engine was rebuilt about 30000km ago, it started doing it about 3000km ago. I'll check the cold start injector.
CAMB01
Postby 10k 20v » Sat Sep 04, 2004 8:42 pm
i'll back matt on that one, sounds like the coolant temp sensor.
Have you tried reading the ecu for fault codes?
10k 20v
Postby Monsterbishi » Sat Sep 04, 2004 10:27 pm
our 4agze acted just like that when we were losing fuel pressure through bad o-rings...
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby Dr-X » Sun Sep 05, 2004 10:14 am
If you state the auto choke is coming out, one would asume it's a carbie, as injected motors dont have chokes :roll:
Dr-X
Cough
Postby CAMB01 » Sat Sep 11, 2004 12:44 pm
4AGE's idle at about 2500RPM when cold, revs drop as the engine warms up.
CAMB01
Re: Cough
Postby Dr-X » Sat Sep 11, 2004 6:09 pm
CAMB01 wrote:4AGE's idle at about 2500RPM when cold, revs drop as the engine warms up.
Was there a point to this post? Or is it just forum diarrhea?
Dr-X
Postby -Dan-Knee- » Sat Sep 11, 2004 9:05 pm
Best bet is normally just to leave the car for abit at idle so it warms up sum what and u may be lookin at less of a prob.
Just like the human body really aye wen ur cold u can't be fuked doin shit but wen ur warmed up and got abit more energy in ya its a dif story den.....
Not sure if i'm exactly right but this is my opinion.
As my oldman and my step dad always tell me Don't give ur car any real pressure wen its cold thats wen it starts spitting the dummy.
Hope this was sumwhat of a help to u???
-Dan-Knee-
Postby kingcorolla » Sat Sep 11, 2004 9:23 pm
Unknown wrote:Just like the human body really aye wen ur cold u can't be fuked doin sh*t but wen ur warmed up and got abit more energy in ya its a dif story den....
well put :D
as for an answer..well im in the middle of a build, so im yet to come across FAST IDLE probs on efi..!
1983 Carina AA63 4age
kingcorolla
Postby Dr-X » Sun Sep 12, 2004 1:21 am
Unknown wrote:Best bet is normally just to leave the car for abit at idle so it warms up sum what and u may be lookin at less of a prob.
Just like the human body really aye wen ur cold u can't be fuked doin sh*t but wen ur warmed up and got abit more energy in ya its a dif story den.....
The point here is that the car sohuld be able to run fine while cold, that's how they're designed. Few people can be bothered waiting for the car to warm up before driving it.
Dr-X
