180 km/hr speed limiter
Postby sprint » Wed Sep 01, 2004 9:56 pm
I was wondering what i can do to get rid of the 180 km/hr speed limiter on my 1G-GTE. Has anyone done it before?
Old Rides:
88 GZ20 Soarer 1G-GTE
81 Ex Lancer
sprint
Postby Al » Wed Sep 01, 2004 10:21 pm
you need one of these
http://www.importscene.com.au/prod547.htm
or a pivot speed meter for around $200nzd which also tells you ur speed
Al
Postby Silent Knight » Wed Sep 01, 2004 10:25 pm
i didn't know the 1G-GTE's had a 180kph speed limit :?
I've been over 180kph in the supra??
Silent Knight
Postby GTUWET » Wed Sep 01, 2004 10:54 pm
speed limits 100km/h :? :roll:
[GTUWET] AnD lEaViN u DRiPpIn!!
GTUWET
Postby adikt » Wed Sep 01, 2004 11:37 pm
well this is OBVIOUSLY for track use isnt it :D :P
right?
wouldnt want to go breaking the speed limits, that would be bad :wink: :wink:
adikt
Postby thaphatty » Thu Sep 02, 2004 12:08 am
hahaha! thats great! damn you crazy! anyone who wants to take off their speed limiter is my kinda person :twisted:
thaphatty
Postby adikt » Thu Sep 02, 2004 12:43 am
i looked at getting a Speed cut defender too, was gonna cost me about $200-300 installed.
that was before a couple of incidents that kinda sucked my dry of any sort of financial backing.
still, its in the plans, do some research & post your results :)
adikt
Postby Al » Thu Sep 02, 2004 1:04 am
if u were in chch a mate of mine sells and installs these for $200 incl
http://www.pivotusa.com/index.htm?/spee ... x.htm&main
Al
Postby sprint » Thu Sep 02, 2004 1:35 am
I was at puke on sunday and was sitting on the 180 limiter down the back straight. So i take it there is no quick fix? You cant bypass it? What about disconnecting the speedo cable? You wont get a speed or rev counter but maybe you can go faster than 180?
Al: if u were in chch a mate of mine sells and installs these for $200 incl
Sorry im in Auck.
Can you install one of these HKS Speed Limit Defencer this yourself?
Old Rides:
81 Ex Lancer
sprint
Postby sprint » Thu Sep 02, 2004 1:37 am
Also how fast has someone got their 1G-GTE up to? And what car was that in?
Old Rides:
81 Ex Lancer
sprint
Postby fivebob » Thu Sep 02, 2004 2:32 am
Here's a < $5 speed cut that works for 3S-GTE's and should work for most other Toyotas :D
Get a 4024 I/C from Dick Smith ( http://www.dse.co.nz/cgi-bin/dse.storef ... View/Z5624 ) then connect as follows;
Pin #1 -> Speed Input ( From Speedo ?)
Pins # 2 & #7 -> Ground
Pin #14 -> +5v
Pin #12 -> Speed output (to ECU)
Cut the speed input to the ECU and put this I/C inline and it should solve your 180km/h problems
Postby Al » Thu Sep 02, 2004 7:51 am
thanks fivebob :D
my flatmate works at dicky smiths so it will be even cheaper :lol:
Al
Postby Rollux » Thu Sep 02, 2004 11:19 am
[quote="sprint"]You cant bypass it? What about disconnecting the speedo cable? You wont get a speed or rev counter but maybe you can go faster than 180?
quote]
Most modern cars have a VSS wire going staright to the ECU from the trans, so pulling your speedo cable is pointless. You could disconnect the VSS wire, but that's not a recommended option, causes all sorts of problems
2002 Allex RS180 6 Speed
Racing a Honda is like competing in the Special Olympics. Even if you win, you are still a Retard.
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Oversteer is when the Passenger is scared. Understeer is when the Driver is scared
Rollux
Postby IH8TEC » Thu Sep 02, 2004 6:07 pm
would this work on an ae92 with afm 4agze?
Postby alastabesta » Fri Sep 03, 2004 2:04 am
Al wrote:if u were in chch a mate of mine sells and installs these for $200 incl
how does the speed limiter works? I don't suppose its those "plug it into ciggy lighter and it'll work"?
I've got a pivot shift light that works off the ciggy lighter and I'm still confused as to how they managed to pick up those slight changes in voltages and trigger the shift light... I tried turning lights on and off to offset the shift light system but it doesn't actually go off... :?
2001 Caldina GT-T
alastabesta
Postby MetalupYoAss » Fri Sep 03, 2004 6:21 pm
find the purple wire with a white stripe that goes into your ecu and put a switch on it, when the switch is closed the car will act like normal with the speed cut but when you open it the engine check light will come on but you can go over 180... no need for expensive gadgets
MetalupYoAss
Postby Dr-X » Fri Sep 03, 2004 6:27 pm
These shift lights use circuitry that picks up the electromagnetic signals output by your ignition system. Same way any good scope looks at duty cycle etc.
Dr-X
Postby IH8TEC » Fri Sep 03, 2004 6:28 pm
MetalupYoAss wrote:find the purple wire with a white stripe that goes into your ecu and put a switch on it, when the switch is closed the car will act like normal with the speed cut but when you open it the engine check light will come on but you can go over 180... no need for expensive gadgets
is this for a 4agze?
Postby Al » Fri Sep 03, 2004 7:39 pm
Is that tried and tested? Because usually when CEL comes on you go into limp mode.
Al
Postby Lloyd » Fri Sep 03, 2004 8:36 pm
lol, just like when you put a switch in for VTEC. Engine check light comes on and rev limits to 6500ish until you restart the car
btw, VTEC at idle sounds stupid :P
Users browsing this forum: No registered users and 32 guests
