Al: if u were in chch a mate of mine sells and installs these for $200 incl
Al wrote:if u were in chch a mate of mine sells and installs these for $200 incl
http://www.pivotusa.com/index.htm?/spee ... x.htm&main
alastabesta wrote:Al wrote:if u were in chch a mate of mine sells and installs these for $200 incl
how does the speed limiter works? I don't suppose its those "plug it into ciggy lighter and it'll work"?
I've got a pivot shift light that works off the ciggy lighter and I'm still confused as to how they managed to pick up those slight changes in voltages and trigger the shift light... I tried turning lights on and off to offset the shift light system but it doesn't actually go off...
MetalupYoAss wrote:find the purple wire with a white stripe that goes into your ecu and put a switch on it, when the switch is closed the car will act like normal with the speed cut but when you open it the engine check light will come on but you can go over 180... no need for expensive gadgets
