g,box whine
g,box whine
Postby gt-trainer » Sun Sep 05, 2004 5:56 pm
my caldy has a whine in 1st gear (auto) :oops: why?hard life boostn in low gears?just normal?also not changing into 4th until warm on guage about 5 mins!!anyone had this weird one?
If it ain't broke...It soon will be.
gt-trainer
Postby Muzzie » Sun Sep 05, 2004 6:54 pm
The not changing into 4th until warm is normal. Most modern cars do it, mores revs in third so motor warms up quicker.
Not sure about the whine though, but I wouldnt worry bout the 4th :)
Muzzie
Regular Poster
ta
Postby gt-trainer » Sun Sep 05, 2004 7:21 pm
was thinkin dat.cheers muzzie.hows the hiace?
gt-trainer
Postby Muzzie » Sun Sep 05, 2004 7:24 pm
Fine :) Just got full tints applied to it yesterday. Now I'm on the look out for some better mags for it. And I'm in the process of wiring a new window switch for the passenger side since both driver and passenger door switches have gone kaput :twisted:
Still gotta find out whats making it run on after the ignition has been switched off though.
Doesn't sound to healthy when it does that.
Muzzie
Regular Poster
Postby Voodoo » Sun Sep 05, 2004 7:47 pm
had a work van that did that, carnt remember why, .... thinking auto choke sticking on if i can remember?
Voodoo
Postby Muzzie » Sun Sep 05, 2004 7:50 pm
Bugger, hope it's not the same on the Ace, auto choke hard to get at :|
I'll have to pull a plug or two tomorrow and see what I can find. And check with Mr. Revhead see what the correct plug heat range should be.
Muzzie
Regular Poster
Postby gt-trainer » Sun Sep 05, 2004 7:51 pm
hows da timing i assume ya lookd at it?auto choke?maybe.
gt-trainer
Postby Muzzie » Sun Sep 05, 2004 7:54 pm
Aint had time to look at it fully. Been struck down with Glandular fever. Hope to have some energy tomorrow so will have a look then. Hopefully :)
Muzzie
Regular Poster
Postby Linz » Fri Sep 10, 2004 4:50 am
have u changed da oil?
Linz
Postby Muzzie » Fri Sep 10, 2004 12:50 pm
Yes. That i have done.
Rang the engine rebuilders and they said it's idling too high. Id have thought 600rpm in drive would be about right.
Muzzie
Regular Poster
Postby RunningRich » Fri Sep 10, 2004 1:51 pm
If wining take it to a gearbox specialist and have the gearbox serviced (ie. oil flush and filters etc, not just a couple of litres of new oil).
Correct plugs and idle speed should be on a label in engine bay somewhere.
Richard
http://gtfour.supras.org.nz
RunningRich
Postby snwtoy » Fri Sep 10, 2004 5:59 pm
Carbon buildup on the top of the pistons is a leading cause of run-on..
There's probably some wynn's treatment that will sort it out :)
snwtoy
Postby Muzzie » Fri Sep 10, 2004 6:14 pm
Hope thats not it, it was rebuilt 30,000km ago. So I'd have thought it must be something simple.
might go back and see them, even if the thing is 10,000km over the warranty period.
Muzzie
Regular Poster
