now need lsd
now need lsd
Postby fxgt race » Mon Sep 06, 2004 5:43 pm
while the gearbox is out i might as well put an lsd in it,it is a c52 gearbox,apart from buying a new lsd is there one i can get out of another gearbox and put it in as a cheaper alternative,or mr revhead what can u offer in lsd's and the price
fxgt race
Re: now need lsd
Postby Monsterbishi » Mon Sep 06, 2004 6:39 pm
fxgt race wrote:while the gearbox is out i might as well put an lsd in it,it is a c52 gearbox,apart from buying a new lsd is there one i can get out of another gearbox and put it in as a cheaper alternative,or mr revhead what can u offer in lsd's and the price
afaik there are no LSD's that'll fit the C52, just the E5x series boxes ;-(
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
lsd
Postby fxgt race » Mon Sep 06, 2004 7:05 pm
the e5x gearbox ,what engine or car are they in and if so will it bolt up to a silvertop and will the mounts be the same as the engine is in a ae82
fxgt race
Re: lsd
Postby Monsterbishi » Mon Sep 06, 2004 7:10 pm
fxgt race wrote:the e5x gearbox ,what engine or car are they in and if so will it bolt up to a silvertop and will the mounts be the same as the engine is in a ae82
Axles will probably need to be changed, iirc the E51 was what was came stock on a Silvertop, how did you end up with a C52?
--- Cut Here ---
Monsterbishi
gearbox
Postby fxgt race » Mon Sep 06, 2004 7:22 pm
i'm pretty sure they came out with a c52 ,even the plate of the car that i got with the engine says this
fxgt race
Postby Nuty|Mike » Mon Sep 06, 2004 7:48 pm
i assumed that any lsd say out of a aw11sc or gtz would fit mmm my bad
wat u do to the gb anyway couldnt it handle alll that 20v power :P
05 Mazda Verisa .....for the Family
Nuty|Mike
nar
Postby fxgt race » Mon Sep 06, 2004 8:00 pm
the gearbox is sweet but i shreaded the clutch to pieces and while the car is in pieces i thought might as well spend a little more dosh on an lsd, those race tracks are car brakers and the was a few there on sat
fxgt race
Postby Nuty|Mike » Mon Sep 06, 2004 8:09 pm
wat cluctch u goin for were u running 16v or 20v one b4
Nuty|Mike
clutch
Postby fxgt race » Mon Sep 06, 2004 8:15 pm
we have a 5 puck ceramic clutch and heavy duty pressure plate going in it
fxgt race
Postby vvega » Tue Sep 07, 2004 12:12 pm
there is a plate type lsd for the c52
also a helical
the e series came out in ze's and sw20's i believe
silvertops have a c series box
both the c52..c56 are the same internal bar gear ratios
bout 1300 for a lsd
and yes there is one in the country right now
its 1.5 way
so prolly more suited to a mr2 but would still be fine in a fwd
if you wanted a cheaper alternative
galanza boxes are c series and some have lsd's
the lsd ones have a extra casing on the back housing the viscous
i guess perhaps a post in the trade secion looking for one might get you more luck :D
vvega
Postby ChaosAD » Wed Oct 06, 2004 7:05 pm
So would the lsd out of a glanza box fit in a c52 box? or is it different cos of the fact thatthe axles bolt onto the c52 gbox instead of slide in?
ChaosAD
Postby ChaosAD » Wed Oct 06, 2004 7:06 pm
ChaosAD
Postby 10k 20v » Wed Oct 06, 2004 7:22 pm
the extra housing on the side has to bolt on somewhere so i think you'd need the whole g/b. and i personally think thats setups crap.
just go and buy the trd one. i would.
there are factory lsd in the c series but chances of finding one are slim
10k 20v
Postby Mr Revhead » Thu Oct 07, 2004 12:54 pm
yeah i have trouble with those... wreckers claim to have a c5# lsd but it turns out usually not.
the glanza ones are viscous and yes some are c series.
what are you using it for? if its a road car a viscous one would be ok, but for racing or serious power a helical one is prob best
Postby vvega » Fri Oct 08, 2004 3:10 pm
the hard part is peole get confused with the hexagon shaft idea of the e series
the only way to well is to put the box in gear and turn one side of the diff
if both turn the same way its a viscous or plate type if one spins without the otherone moving its a helical or torsen type diff
if they turn opposite its a open
this has worked for me sofar but please dont take it as gospel
the c56 out of the galnza will bolt up and is prolly the easiest option
trust me its a hard path to find the perfect box for the 4age c series boxes
beat of luck
v
vvega
