HZRDIZ wrote:Ok I've been looking around for mods to make on the Levin and have come up with a list thats reasonable:
-0.8mm Head
-Aftermarket Trumpets
-Either a big foam pod or normal with induction pipe (i have no idea which is better)
-Change the cams
-Short Shifter
... and so forth
Has anyone done these mods and do they make much diff?
Mr Revhead wrote:i recenty went for a ride in a b/t ae111 rally car that had the head and cams done by kelford, it also had 12.5:1 pistons in it and a motec ecu, so it was a bit more than 'light' mods, qouted at 180hp atw, i have no idea how credible the power figure is however it really HAULED!
have it setup to use vvt all the time for more power,
Mr Revhead wrote:
setting the vvt like that is ok on a competition vehicle... or as mentiones just fit some solid adjustble pulleys.
Mr Revhead wrote:i can do a head gasket
