piston regrooving
piston regrooving
Postby kingcorolla » Tue Sep 07, 2004 7:50 pm
hey guys,
my shortblocks at the re-conditioners at the mo, i was jus wondering, after getting my pistons regrooved, will factory spec rings still be appropriate to seal? or is there slight variations of O/S rings?
1983 Carina AA63 4age
kingcorolla
Postby Gadget » Tue Sep 07, 2004 8:33 pm
If you change the width of the ring groove, you will require new rings to suit. I'm not sure if they do over-thickness rings.
IMO you'd be best to replace the pistons if they have ring-groove issues. Go to .5mm (.020") oversize, and then get the rings to match (would normally come with the pistons).
Gadget
Postby kingcorolla » Tue Sep 07, 2004 8:53 pm
there is no issue in the piston grooves, just a general procedure in a rebuild.
I aint gonna bother with new pistons, 1st of all coz its a N/A 4a-ge, second of all, coz i already have had some costly probs in the bottom end, that need fixing. eg. 2 run bearings, wrong crank/rods (42mm) in a 3 rib block. Grrrrrrr ended up buying basicly a new shortblock!!
the re-grooving is just a recon option i have chosen, and is just wondering if facory rings will be acceptable. I am not expecting big alteration in the original grooves.
kingcorolla
Postby solberg Fan » Tue Sep 07, 2004 9:12 pm
You have the wrong crank and rods?? 8O Sounds like the guy who did your engine did mine too. :x
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
Before you judge someone, you should walk a mile in their shoes. That way, when you judge them, you're a mile away and you have their shoes.
solberg Fan
Postby kingcorolla » Tue Sep 07, 2004 9:27 pm
ye it sucks. He sed it was a bluetop, with red/blacktop cam covers...
turned out to be a red/blacktop with a 3 rib block! idiot! :x :x
and i dont have any measuring tools, so i couldnt confirm the size of the crank etc.
lucky im rebuilding it, that engine was F-F-F-FUUUKKKDD
brought it dirt cheap tho :wink:
kingcorolla
Users browsing this forum: Bing [Bot], Google [Bot] and 22 guests
