minijrocks wrote:have you seen the pics that i put up a little while back for a ae101 4age engine bay? if its the same, you can see which wires it is from there.
aesc wrote:Ok thanks dude, will try that sounds easy enough.
genuine as I need to hook up my gizzmo shiftlight / launch controlleraesc wrote:EVLGTZ wrote:how had is it to pull the old cluster on on the ae101s?
Is that a genuine question or are you saying its easy?
Bazda wrote:i tried to hook my powerlink up to ign - on the back of my dash board but it stole the signal to the rev counter and that didnt work then.
So maybe u need some special box the does something, someone told me to use soemthing off a vr4 i cant remember what is is though.
I just ended up using ign - off one of my coils and that was ok but only gets half the signal, its ok for a powerlink cos u can adjust the pulse but prob not good idea for a shift light.
NA Drifter wrote:emm.. The "IG" will be the ignition power, try "guessing" which is -ign. Try guessing from behide the rev counter.. I'll guess one of the srews will be it. use a multimeter to help you.
kingcorolla wrote:im guessing, IF u are still keen on runnin it off the C.A.S, "i think" they function the same way to a optical electronic distributor.. i think.
