4AG Ignition Module & Manifold
Postby fryguy » Sat Sep 11, 2004 12:14 am
HEY ALL,
I am putting twin weber dcoe 40mm carbs onto my red top 4ag and I was wondering if anyone could recommend a good ignition module to use for this- I have checked out bosch modules on the net and they seem okay would they just be a simple plug and play exercise? all I need out of the module is a breaker for the coil, no advance necessary as Im not looking for fuel economy if you catch my drift :twisted:
ps- if anyone could offer a lead to where I could start looking for a manifold for the carbs that would be great!
CHEERS.
BILL
You're a special kind of normal,
You're ABNORMAL.
fryguy
Postby ee904age » Sat Sep 11, 2004 3:34 pm
Cant help with the module but check out Pioneer Autoparts for the manifold, they list a Redline manifold for both big and small port 4AG's
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby kingcorolla » Sat Sep 11, 2004 4:34 pm
kelford cams for thew manifold dude, they got wat u want there.
1983 Carina AA63 4age
kingcorolla
Postby atmosports » Sat Sep 11, 2004 5:24 pm
Pm me or call HiTech Motorsports in Pukekohe on (09)238-8754 for a manifold, should be cheaper than a redline from pioneers & kelfords. Hitech supply Palmisde, Autoquip etc.
atmosports
Re: 4AG Ignition Module & Manifold
Postby matt dunn » Sun Sep 12, 2004 8:38 pm
fryguy wrote:no advance necessary as Im not looking for fuel economy if you catch my drift :twisted:
CHEERS.
BILL
Um..
Advance is where the power comes from.
Vacuum advance is for economy but mechanical advance is required to make some power. Only exception i've seen is a race car we were having trouble with where we fixed the timing at 36 deg BTDC all the time.
This is not suitable for a road car and requires the car to be turning over on the starter before you turn on the ignition.
If you set it an the normal 8 BTDC it will be a slug!
Best option is to modify a 4K electroinc dist into it.
This is a common soloution.
matt
