ae85 diff head in ke35 housing
Postby crispy'86 » Sun Sep 12, 2004 7:16 pm
done a search and came up with nothing. Can i put the head and axles from an ae85 into my housing on my ke35, i am more then aware i may have to machine splines and shorten the axles. I've got 3 heads and 2 sets of axles, already measured the axles from the '85 they are 23mm longer than 35 but haven't compared the diff heads for bolt up yet. Could i put them in with a bit of machining, my diff can't handle the power change from 3k-2tb-2tg been a bit sad for a while but now it's driving me mad
crispy'86
Postby MetalupYoAss » Sun Sep 12, 2004 9:06 pm
probably easier to swap the whole differential and the housing/big drum brakes over while your at it, saves you machining parts to try make them fit; pluss if you swap the whole ae85 rear end you'll have more rear track so the wheels will stick out further :twisted:
MetalupYoAss
ae85 diff head
Postby crispy'86 » Thu Sep 16, 2004 6:14 pm
I'm not swapping a whole housing over just for the work involved, got an engineer at back of work that looks after us. It can be done yes or no????
crispy'86
Users browsing this forum: Bing [Bot] and 16 guests
