NOS on a 4age
NOS on a 4age
Postby ants_ae92 » Mon Sep 13, 2004 4:59 pm
For me this is seen as horsepower in a bottle.
My question is whether any modifications are needed to injectors, fuel etc. Or can a kit be added directly to a 4age. Will the standard fuelling system be able to hack it and how much do these kits cost.
Also any other info on the giggle gas would be great!
ants_ae92
Postby levin_it_large » Mon Sep 13, 2004 5:08 pm
have a talk to 8thsin about this he had it in an AE111 levin
levin_it_large
Postby Al » Mon Sep 13, 2004 5:11 pm
Im looking into nitrous as my next mod and have done a few weeks worth of researching it. Its only good for the dragstrip tho, as it can only be used at wide open throttle. IMO nitrous on the street is just dangerous.
Basically what you wanna do is freshen up the ignition, new leads, cap, rotor and one step colder ngk plugs (BCPR6ES) and a new fuel filter.
You really want a wet kit that draws its own fuel supply rather than relying on the injectors to push out the extra fuel required for a dry kit. Wet does cost slightly more and its harder to install but its worth the effort for the peace of mind :) Start with a 50 shot nozzle and then put the 75 shot nozzle on if you think you need more power 8)
Al
Postby kingcorolla » Mon Sep 13, 2004 5:35 pm
did anyone see the top gear, were they put like 100shot in an old XJ6 jag..? And it beat the porsch carrera turbo and all those other sports cars! on a whole shot! on a 1/2 mile drag! Would of melted the rings, and probably pinked like a bugger the hole time!
sorry this is off topic talk AL.. but just thought that episode should be remembered! *end of wasted bandwith*
1983 Carina AA63 4age
kingcorolla
Postby Al » Mon Sep 13, 2004 5:41 pm
Yup that was quite impressive. Shouldnt have pinged because of the supercooling effect nitrous gives when released. Its at -88 degrees C when its released into the combustion chamber.
Al
Postby kingcorolla » Mon Sep 13, 2004 7:54 pm
o true..
but just imagine.. factory internals, comp ratio, chucking all that nos in, in one drag race, thaats a big load on the old motor,
wouldnt that be similar to strapping a huge turbo, high boost, just for one drag..? bet the rings, and the piston skirts are now ONE ITEM 8O :D
kingcorolla
Postby Al » Mon Sep 13, 2004 7:59 pm
Yeah the general rule of thumb is no more than half your flywheel power on a stock internalled motor :)
Al
Postby 92GTApex » Mon Sep 13, 2004 10:52 pm
Didnt they use a 200hp shot?
300 odd horsepower to over 500?
Logan
Current ride: 92 Levin GT Apex
Current project: 91 Levin GT Apex (Crashed - It wasnt me)
www.area-51.co.nz
www.toyperformance.org.nz
www.lextreme.com
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1731
92GTApex
Postby kingcorolla » Tue Sep 14, 2004 12:47 am
92GTApex wrote:Didnt they use a 200hp shot?
ye i think so, i cant really remember :P
92GTApex wrote:300 odd horsepower to over 500?
i think it was just an XJ6, they only like half that power, correct me if im wrong tho
were drifting off the topic, but what we are talking about is N.O.S = BIG GAINS!! if prepped correctly, I agree with Al when he says to replace leads, dizzy cap etc, seems like a logical idea.
but it depends on how much use it would get, eg. racecar - daily driver..
if it for racing application.. maybe you should start to think about shortblock upgrades..? *shrugs*
kingcorolla
Postby Al » Tue Sep 14, 2004 1:01 am
As I mentioned earlier IMO its only good for drag racing
if you want to run more than a 75 shot it will prolly get expensive :)
Al
Postby Adamal » Tue Sep 14, 2004 7:46 am
4.2L 6 cyl inline XK6 engine that was in the XJ6 Jag's (and the Mark II) produced 210 hp :)
Postby -Dan-Knee- » Tue Sep 14, 2004 7:50 pm
any1 seen that oldskool skyline on HO Overboost on NOS??? 50hp then 100hp then 200hp shot i fink.
The top shot spat shit all over the track... :lol:
Sorry kinda off topic again!
-Dan-Knee-
Postby FLAWLES » Wed Sep 15, 2004 6:52 pm
u can run a 50 to 75 hp dry shot of nos with no props
u wont need to run any more injectors or rase the comp just like al said new leads etc will do the trick
oh i think you have to ether retarde or advance the timing cant remeber witch one
i was looking to do this to a turboed laser ive got a book " from breanan racing the importers of Nos " i can put up more info if u want?
FLAWLES
Postby Al » Wed Sep 15, 2004 8:22 pm
I wouldnt even bother retarding the ignition. I could give you a list of 50+ guys in the US that use 50 and 75 shot nitrous on stock internalled 3sgte's with stock 10 degrees BTDC :)
Al
Postby pidge » Wed Sep 15, 2004 11:45 pm
I've got a aquiantence who NOS'd his 70's Fiat. He went through 3 bottles in three weeks after installing it...
pidge
Postby ants_ae92 » Thu Sep 16, 2004 1:34 pm
Yeah info would be good at the mo. Just want to learn the ins and outs, do's and don't. Im just doing what Al is. Trying to get as much info and read heaps of stuff.
Only using it at full throttle is a good thing otherwise I would use too much of it. And would only want to use it at full throttle, ie drags and a dyno run.
ants_ae92
Postby Al » Thu Sep 16, 2004 1:42 pm
Well if you try to use it at anything less than full throttle you can kiss your motor goodbye.
I'll pm you a link later to the MR2 OC site, theres a really good FAQ on there regarding nitrous :)
Al
Postby ROBODISCO_20v » Sat Sep 18, 2004 4:37 pm
Email Kelford cams & they will quote you a price & recomend what size bolt on kit you can use with your standard engine.
They quoted me $1150 +gst for a 75hp dry ZEX kit for my AE111 BZG. Dont know if that included install though??
ROBODISCO_20v
Postby Al » Sat Sep 18, 2004 8:08 pm
Nah thats just the kit mate.
Im kind of partial to the safety of a wet kit because it doesnt rely on your injectors adding the extra fuel, can 4age injectors handle another 75hp worth of fuel?
Al
Postby kingcorolla » Sat Sep 18, 2004 11:33 pm
kelford do a 55-75 HP dry kit for $1150+
or a 75-125 HP wet kit for 1250+, and bottle fills for $180. Hey AL have u herd of those bottle heaters, to stop density in the bottle from coldness? Kelford do them for $260+
just caught a kelford ad in a magazine.. :oops:
maybe for a road AND track car, u could run a switch from the microswitch on the throttle, controllable from the cockpit?
kingcorolla
