alternator upgrade
alternator upgrade
Postby the fallen303 » Sat Sep 18, 2004 7:14 pm
just wondering what can be done to upgrade the alternator on a 93 nz new 4a-fe? is there another one that will bolt up? looking for something to be able to run a reasonable sized stereo system, two amps, 1 sub, few tv's, etc... amp's won't be huge, but still reasonable.
any ideas?
thanks
true house of JZ
Stay true to the origin
the fallen303
Postby Lloyd » Sat Sep 18, 2004 11:27 pm
Standard alternators should be alright in most cases. I've used to run my stereo fine on a factory 4AGE alternator and never had any issues.
Old boot: http://www.canze.org.nz/forum/hosting/ACFD1A0.JPG
Postby matt dunn » Sun Sep 19, 2004 4:48 pm
HRT wrote:Standard alternators should be alright in most cases. I've used to run my stereo fine on a factory 4AGE alternator and never had any issues.
agreed
I think you'll find that your 4Afe alt is probably capable of close to 80 amps.
Do you really need more power than that?
Postby the fallen303 » Sun Sep 19, 2004 6:48 pm
wasn't sure on what it was producing, so thought it might pay to look at upgrading, just incase i do go for a bigger system. thanks to what people have said, means i don't, and can focus on changing other things instead :)
thanks guys
true house of JZ
the fallen303
Postby kingcorolla » Sun Sep 19, 2004 7:17 pm
just a quick note,
the alternaters in 4a-fe with an auto trans have a higher output current than manual box.
dont know if the rectifiers match tho..
1983 Carina AA63 4age
kingcorolla
Users browsing this forum: Google [Bot] and 33 guests
