do ae85s have LSDs?
do ae85s have LSDs?
Postby l1ttle_d3vil » Thu Sep 23, 2004 9:23 am
simple question - ive been told both yes and no. do ae85s have LSD diffs???
Postby TRD Man » Thu Sep 23, 2004 10:51 am
I think it would be unlikely that there was a factory option LSD for this model.
TRD produced an LSD for it but these were discontinued a couple of years ago.
TRD Man
Postby Mr Revhead » Thu Sep 23, 2004 4:47 pm
hehe no ae85 came factory lsd.
Postby AE85.6 » Thu Sep 23, 2004 5:48 pm
never know, they may have prob just never reached our shores, there are freak models of bits and peices that just never made big production and stayed in japan, but as an 86 rear end came factory i think they would have used that instead, so an 85 lsd would be pretty unlikely.
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby Adamal » Thu Sep 23, 2004 6:35 pm
If you watched Initial D, you'd know that they didn't ;)
LSD
Postby Grotty » Thu Sep 23, 2004 7:44 pm
I got a lsd from an ae85 diff at pick a part about a year ago.
so yes 85 came with lsd.
Grotty
Postby Adamal » Thu Sep 23, 2004 10:51 pm
Well it's possible to put one in an AE85, but it wasn't a factory option.
That was probably the left overs of a 85.6 conversion that someone had done :)
ae85 l.s.d.
Postby crispy'86 » Thu Sep 23, 2004 11:03 pm
No ae85's came out of factory with l.s.d., only time one would have one is if someone put one in at some stage with either ae86/te71 diff or kept ae85 diff and put one in that.
crispy'86
diff
Postby Grotty » Fri Sep 24, 2004 9:37 am
nope this is an ae85 diff, smaller than 6.7 because i got it for my 86 diff thinking i got a lsd for 65 bucks! also thinking someone had put a t series drum brake diff in the back because why would there be an lsd in a poos 3a powered car that was also an auto beast..
but is to small and doesnt bolt into the t series 86 diff., Its bigger than dx because it didnt bolt in that.. its about 6.3 and bolts into my 85 diff housing, fits axles etc....
So either aftermarket or factory, rest of the car was stock, and rusty!.
It was a treuno facelift coupe, 1986. Diff is mechanical, locks by gears.
Grotty
Postby Mr Revhead » Fri Sep 24, 2004 10:28 am
there is only one diff listed for the ae85 and its not lsd.
if you find an ae85 with an lsd its after market. there may have been a hiace or something that used the same centre as the ae85 and some one transplanted that. but you could NOT get an ae85 with factory lsd
Postby AE85.6 » Fri Sep 24, 2004 6:03 pm
actually that kinda makes sense if it was out of an auto, the AE85 i was gonna do up had a locker in it so i bought a spare rear end which was out of an auto, the donor car was absolutly rooted rusty as and smashed but had low ks, also being a one lady owner i guess it never really got thrashed, anyways i put this into my AE85 and it worked awesome, granted i only had 14s on it that were not that wide or gripped that great but it slid so easy and did two wheels when ya held a foot on the brake, i think the auto ones must just be more tightly wound or something also they are possibly geared different to ones from a manual so that also could have helped. i know it wasnt an lsd but worked similar to one although this was all low speed testing as my trusty 3au was moaning at me for trying it at even slow speeds :?
AE85.6
Postby sleeektoy » Sat Sep 25, 2004 6:55 pm
An AE85 i saw at a wreckers in patiki rd rosebank over a year ago, had a factory LSD in it . The chassis code was definitly AE85 and the diff code was S413. I checked the diff as it was already jacked up and im absolutly certain it had the LSD in it. It also had an Auto(A41) gearbox in it.
The only other car ive seen a "S" series (6.38 inch) LSD diff in is an 83 starlet
Old school Celica Nuttr x 3 (collection increased)
昭和49年 トヨタ セリカ LB GT (TA27) :D
昭和47年 トヨタ セリカ TRD(TA22)
昭和52年 トヨタ セリカ LB GTV (RA28)
sleeektoy
Postby Mr Revhead » Mon Sep 27, 2004 9:30 am
the only lsd in the ae85/ae86 range is in the ae86 with the trans code t283.
anything else is NOT factory fitted. it may have been factory in something else, but not the ae85/86
Postby sleeektoy » Mon Sep 27, 2004 9:04 pm
Why then would it have on the chassis plate " S413 " as a diff code
According to toyota's records this code works out at
S = 6.38 inch crownwheel
41 = 4.100 ratio (or 4.556)
3 = 1.5 way Limited Slip Centre (factory fitted)
and the chassis code was AE85-*****
sleeektoy
Postby Mr Revhead » Tue Sep 28, 2004 10:38 am
well in that case go buy it cause its an extremely special and rare car.
cause according to toyotas records NO ae85 was factory fitted with an lsd.
get me that model code, id love to know more about that car.
Postby sleeektoy » Tue Sep 28, 2004 1:56 pm
Cars like that just dont last here in Auckland, I did go back to get it and the whole car had already been purchased from the wrecker.
In japan i believe they had the "tick the options" form when ordering an AE85/86 and one of the options was the LSD. Along with other crazy stuff like a factory baby booster seat. I have a picture of a brochure somewhere with the options on it (in japanese of course)
sleeektoy
Postby Mr Revhead » Tue Sep 28, 2004 2:27 pm
hmmm i could understand it being a dealer fitted option, but theres no record of it being factory which is odd cause if its factory they would at least have a listing for the clutchs etc for repair
