FLAWLES wrote:i
drain the oil and look for shinny bits in the metal " you rings and bearing mite be shot " or oil pump but i dobt it would be this
When the oil hit the crank it made that sound.... must have been REAL hot down there... smoked a bit too
Silent Knight wrote:well i had a listen to it and didn't hear any gurgling etc. sounds coming from the motor. there was a bit of oil round the rocker covers and gasket etc.
like i said before drain out excess oil and clean engine gud all round. warm up and take for little drive then check again if you can see any oil leaking from anywhere.
there's nothing else that i can see/hear that might be wrong the motor cept for oil overfilling which is bad if it's too full.
Users browsing this forum: No registered users and 27 guests
