[4age] oil
[4age] oil
Postby agrath » Fri Sep 24, 2004 5:04 pm
okay so maybe im a noob or something
4age engine + fully synthetic 5w-40 = bad?
i made the mistake of putting this in, and have been having heaps of problems with smoke from manifold and oil leaks. blew an oil filter gasket last night.
Just trying to confirm that yes, it was a bad oil to put it
i'm getting weird oil-in-frying-pan like noises when i come to a stop, (its fine while moving) and lots of smoke when i come to a stop (like at the lights or something). when i switch the engine off the noise gets worse for a few secs then dies away... lots more smoke when i come to a stop too.
so
1) this is a bad oil
2) will it have done any permanent damage?
3) what should i replace it with, brand and ratings
4) where sells 3) cheapest cause i'm absolutely broke
please refrain from calling me an idiot etc, cause i made a guess as to what oil to use and it looks like i chose badly. I did however ask a few people before i put it in, and everyone seemed to say "it'll be fine"
agrath
Postby Mr Revhead » Fri Sep 24, 2004 5:26 pm
um, you didnt spill it did you?
personally its a little thiner than id use.
Postby agrath » Fri Sep 24, 2004 5:44 pm
I didnt spill it, though perhaps i did a little around the outside of the filler hole... not much though
the gurgling-ish noise is whats worrying me, combined with smoke when i come to a stop...
currently i'm thinking its either too thin oil or too much oil. there's a chance that i put a little too much in when i filled it up this morning - but would that cause tonnes of smoke to come off the manifold?
Gareth
agrath
Postby Mr Revhead » Fri Sep 24, 2004 5:47 pm
how much is a little to much?
i dont think a simple oil change would cause the things you mention
Postby Lloyd » Fri Sep 24, 2004 5:54 pm
Ummmm.... wouldn't a look at the dipstick tell you if there is too much in there or not?
As for the smoking, if its off the manifold then its probably just oil burning off. How long has it been doing it? When you change a filter make sure that the old rubber seal from the old filter is off and that the new one sits in place properly. I've put a filter on before and had the old seal still there and it pissed oil everywhere. SOmething like that (but not as severe) could squirt oil onto a manifold and cause smoke/fire.
Postby agrath » Fri Sep 24, 2004 5:59 pm
okay car has been sitting for about an hour and i checked the dipstick
i definitely overfilled it, its about 5mm maybe more above the F line.
Crap. I hear this can be really bad. I've driven it maybe 10km since putting the oil in, and i didnt take it above 4k rpm, used brakes to slow down, not engine etc...
i can drain it out obviously...
this leaves me with the question of
is the gurgling / oil frying sound when i come to a stop or switch the engine off (momentarily) because i overfilled it or has damage been done?
I dont think the smoke coming off the manifold is excess oil burning off, i'm talking a lot of smoke, like i just threw a cup of oil on the manifold while it was hot... i cant see a lot of smoke when im driving, its only when i came to a stop and a few seconds after that the smoke came out...
agrath
Postby agrath » Fri Sep 24, 2004 6:02 pm
oh yeah, and definitely no rubber from old filters left behind
the smoke and the gurgling is only when i've come to a stop after driving for a bit... doesnt do it when i've just started it up and its idling...
G
agrath
Postby FLAWLES » Fri Sep 24, 2004 6:17 pm
if its magnatec u will have some probs its to thin when warm and it sticks to the knock sensor making the engine retard it self
i would
drain the oil and look for shinny bits in the metal " you rings and bearing mite be shot " or oil pump but i dobt it would be this
FLAWLES
Postby ee904age » Fri Sep 24, 2004 6:30 pm
I use valvoline 5w40 in my bluetop and have had no side effects whatsoever, engine is running perfect with no smoke etc even at 6k+ rpm.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby agrath » Fri Sep 24, 2004 6:36 pm
this is shell helix ultra 5w-40 in a silvertop 4age 20v... but im getting the impression the oil is probably too good for the engine but wont do it any harm
Gareth
agrath
Postby RedMist » Fri Sep 24, 2004 8:33 pm
I run Valvoline Durablend 5/30 in the race engine and have strictly used Mobil 1 5/15 in my 20 valves without issue. In actual fact I was most impressed with the Mobil 1 as I heat siezed an engine in the Woodhill race, once back in CHCH the engine freed itself! Raced that engine for another two races.
A well worn engine would probably require a denser oil.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
[4age] oil
Postby jondee86 » Fri Sep 24, 2004 8:40 pm
The only time I ever heard that popping, bubbling, frying sound was when I ran a car hard with next to no oil in it. When I heard the bearings starting to knock I pulled into the next servo and chucked some oil in. When the oil hit the crank it made that sound.... must have been REAL hot down there... smoked a bit too :oops:
Check your water.... look inside the radiator, don't rely on the gauge. The engine will get nice and hot if you lost your water and didn't notice.
Oil viscosity is not that important, so long as you have enough in there. And a few mm over the full line is not a biggie.... no engine sold to the public will be damaged by having 250 ml too much oil :)
Cheers...... jondee86
Watch this space >>> <<<
jondee86
Postby skoty » Fri Sep 24, 2004 9:22 pm
FLAWLES wrote:i
Been there, done that :roll: :roll: :roll: Quite a scaring and costly experience!
skoty
Postby agrath » Fri Sep 24, 2004 9:26 pm
I think my oil is overfull and when it heats up it hits the crank and makes the sound... i'm gonna drain some out tommorrow and give the engine a good clean as suggested by slntkngt (he came over while he was out this way and reved the car a few times and had a listen, he seems to think theres no permanent damage and its just too much oil)
I suppose I could probably do it now, in fact I might.
agrath
Postby Silent Knight » Fri Sep 24, 2004 9:59 pm
well i had a listen to it and didn't hear any gurgling etc. sounds coming from the motor. there was a bit of oil round the rocker covers and gasket etc.
like i said before drain out excess oil and clean engine gud all round. warm up and take for little drive then check again if you can see any oil leaking from anywhere.
there's nothing else that i can see/hear that might be wrong the motor cept for oil overfilling which is bad if it's too full.
Silent Knight
Overfill
Postby CAMB01 » Sat Sep 25, 2004 12:26 am
If you overfill and engine say 1/2 a litre or more the crankcase has trouble breathing and forces the seals out causing oil leaks, learned from experience.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby agrath » Sat Sep 25, 2004 1:17 am
Silent Knight wrote:well i had a listen to it and didn't hear any gurgling etc. sounds coming from the motor. there was a bit of oil round the rocker covers and gasket etc.
yup tho it only gurgled when i stopped after actually driving rather than just idling and reving engine. i drained some out tonight and did all the cleaning too... so tommorrow i have to check the oil and take it for a drive...
yes i did it in the dark, in the rain and with a broken ratchet. Win.
agrath
Postby Mr Revhead » Sat Sep 25, 2004 10:09 am
doesnt take much oil to make a lot of smoke... a table spoon on a manifold is enough to make it look like youv got a dozen pot heads under ya bonnet.
Postby agrath » Sat Sep 25, 2004 12:07 pm
okay, i drained some oil out, then topped it back up to fullish...
let it idle for a few mins
then took it for a 500m drive around the block...
when i pulled back into the drive and stopped to check the car, there was lots of smoke, and a crackling noise
a few moments later i looked at the dash and the light under the oil light had come on, radiator i think...
temp was okay
since i used water to try and wash some excess oil off, (yeah i know oil and water dont mix but im broke) is this likely to be just excess water burning off the outside of the radiator raising the temp?
i'm getting most despondant
agrath
Postby jondee86 » Sat Sep 25, 2004 7:30 pm
Man !!!! It sure sounds like you are running without water !!! If the engine is hot enough to fry the oil it should have been blowing steam like geyser !!!
No steam means no water.... and the gauge won't tell you the engine is hot because it needs water around the sensor to get a reading. My apologies if you already checked the water level, but it's the things you take for granted that often catch you out !!
Cheers..... jondee86
jondee86
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
