SW20 turbo lag question...
Postby Pies » Fri Sep 24, 2004 7:08 pm
for a mate,
when driving the standard mr2 sw20 turbo, does it have much lag? completely standard (apart from a pod filter)? drving his it feels like its holding back for a few seconds before boost kicks in, yet it is very standard so i wouldnt have thought that there would be no lag?
cheers for your answers in advance
Current Rides:
Pies
Postby vvega » Fri Sep 24, 2004 8:01 pm
ct26 or ct20b ??
vvega
Postby Al » Fri Sep 24, 2004 8:21 pm
You should have full boost by around 3000rpm regardless of ct20b or ct26 and it will kick you in the teeth at around 4000rpm, ct26 will then taper off after 5500rpm and ct20b will pull till 7250rpm rev limiter :)
Al
Postby Pies » Fri Sep 24, 2004 9:16 pm
chur chur!
cant remember if itsa 26 or a 20 :? its a 1990 gt lol :oops:
Current Rides:
Pies
Postby Al » Fri Sep 24, 2004 10:07 pm
its a ct26 then 8)
Al
Postby Akane » Fri Sep 24, 2004 11:09 pm
ct20b full boost at 3000rpm? LOL, pass me some of that stuff you're smoking.
Postby Al » Sat Sep 25, 2004 12:02 am
Akane wrote:ct20b full boost at 3000rpm? LOL, pass me some of that stuff you're smoking.
I said 'around 3000rpm'
I've got 15psi by 3100rpm on my ct20b in 3rd and above.
courtesy of a 3" straight exhaust and my greddy profec b
a stocker gen2 with ct20b would still pull its 10-11psi by 3100rpm
Al
Postby Wildcard » Sat Sep 25, 2004 12:56 am
From my experience - 5th gear... 1bar of boost by 3300rpm :)
Wildcard
Toyspeed Founder
Postby fivebob » Sat Sep 25, 2004 1:03 am
Checking through my logs I get .7-.8bar by 3000rpm Excepting when I retard the ignition or have a blown knock sensor, then it's 1.4bar by 3000rpm, all that boost and no power :(
Postby Adamal » Sat Sep 25, 2004 2:13 am
Last I recall, I didn't have any boost anywhere NEAR 3000rpm.
But that could be because my MR2 is N/A :mrgreen:
Postby GT-T » Sun Sep 26, 2004 9:55 am
Hi Fivebob, do you have a boost cut defender installed? My ST215W only can boost up to 1.2bar and the computer cut the fuel supply. :(
It's funny that I record the highest boost was 1.3bar (that was just millionsecond before the fuel cut) hehe
1999 Caldina GT-T
2000 Merc A160
1998 Integra Type R
http://toyspeed.blakjak.net/profiles/profile.php?id=581
GT-T
Postby YTWGN » Sun Sep 26, 2004 10:38 am
Thats quite alot of boost for the GT-T isn't it? I only run up to 1 bar.
YTWGN
Postby Akane » Sun Sep 26, 2004 2:57 pm
fivebob's figure sounds right if your ignition timing is on the spot.
Postby fivebob » Tue Sep 28, 2004 12:20 am
GT-T wrote:Hi Fivebob, do you have a boost cut defender installed? My ST215W only can boost up to 1.2bar and the computer cut the fuel supply. :(
I had a HKS F-ConS piggyback computer, fuel cut was around 1.4-1.5bar
YTWGN wrote:Thats quite alot of boost for the GT-T isn't it? I only run up to 1 bar.
And that's all you should run without an aftermarket EMS, unless you like replacing broken pistons :evil:
Users browsing this forum: Bing [Bot] and 24 guests
