KE70 Best Diff to use?
Postby 12aKE70 » Sat Oct 02, 2004 6:02 pm
Hi guys, just wanting a few opnions on which would be the best diff for a 12a Ke70.
Are there other toyota ones that will bolt up that are a bit stronger?Or will I have to do some modifications to them to make them fit.
Any help would be mint.
12aKE70
Postby YeMs » Sat Oct 02, 2004 7:13 pm
the ke70 diffs are alrighty ay, they wil handle a fair thrashing .. only down fall is they r a single spinner.. thats wen u get the welder out
Your local Hybrid Elite tech
YeMs
Postby kingcorolla » Sun Oct 03, 2004 9:26 am
YeMs wrote:the ke70 diffs are alrighty ay, they wil handle a fair thrashing ..
ye, handle a thrashing from a 4k, more power and they shitt their daks.
this topic has been done before. do a search
1983 Carina AA63 4age
kingcorolla
Postby 12aKE70 » Sun Oct 03, 2004 12:23 pm
Yeah Ive searched a bit and found a bit of information, but didnt find want I wanted to know.
And yeah they can handle k series engine thrashings
but arent that great when theres a rotary powering them,
well maybe someone can point me in the right directions?
12aKE70
Postby fangsport » Sun Oct 03, 2004 4:23 pm
make up some 4 link mounts and put a van diff in it. bigger axles and bigger diff gears.
fangsport
Postby l1ttle_d3vil » Sun Oct 03, 2004 9:18 pm
definatly not ke70 diffs. a guy i know only turboed his 4k and ended up blowing his diff not long after so id be pretty suprised if it handled a 12A.
Postby suberimakuri » Mon Oct 04, 2004 12:31 pm
hilux.
suberimakuri
Postby 12aKE70 » Mon Oct 04, 2004 9:34 pm
if I go hilux etc i wouldnt be able to run 13inch wheels which i want to as I like the old skool look.
Wondered if maybe a corona or celica diff could be modifyed,how hard would it be to change to 4 link?
Or maybe a diff from another manufacter would fit,just wondering what different ones people have used?
I pulled the old diff out today,jeez it was in a bad way
12aKE70
Postby suberimakuri » Mon Oct 04, 2004 9:44 pm
i can run 13x7 hotwires with my hilux diff.
suberimakuri
Postby 12aKE70 » Mon Oct 04, 2004 9:51 pm
oh ok interesting so what did you do to take it from a standard hilux diff to make it fit on your car? and run 13inch wheels
12aKE70
Postby MetalupYoAss » Mon Oct 04, 2004 9:56 pm
how hard would it be to convert a ke70 wag to G series IRS suspension?
MetalupYoAss
Postby fangsport » Mon Oct 04, 2004 10:03 pm
MetalupYoAss wrote:how hard would it be to convert a ke70 wag to G series IRS suspension?
ask callum(purple beasty), he has/is doing it to a starlet. it depends how clever you are or how much gorse ya got.
fangsport
Postby suberimakuri » Mon Oct 04, 2004 10:04 pm
ask Tim from GD.. he might build one for you.
suberimakuri
Postby wde_bdy » Mon Oct 04, 2004 10:18 pm
Mine is an F series from the *A6* series Celica/Carina/Supra, not worthwhile in most circumstances as it is a trailing arm setup. If you were going to do it you should look at a Nissan S13/14/15 setup. Width is probably a bit closer than the G series from the Mk3/4 Supra, and good aftermarket support. You really don't want to narrow an IRS if you can avoid it.
Not really worth it at all, the money could be better spent elsewhere.
Callum
wde_bdy
