jacko wrote:-Whats the 1/4 mile time of standard map ae92 gtz?
jacko wrote:-Whats the best bang for buck pulley kit around?
jacko wrote:-Is it going to make my 4agze pop (170,000km but runs nice and looked afta)
jacko wrote:-What hp would a stock 4agze running 12-14psi make?
this has been asked a few times. If its the MAP sensored model, its probably the ECU. Seems to have some kind of safety feature where it cuts the power for some reason at around 5500rpm. Due to the nature of the roots type SC12, they become inefficient over ~6000rpm, hence the drop in power. The AFM models don't seem to have the same power cut as the MAP sensored models, but they do still run out of puff. The air the supercharger is compressing becomes too hot for the s/charger to continue providing any beneficial boost. Superchargers also drain a bit of power from the top end, as the engine is providing the power to turn the compressor.jacko wrote:-Why does my car drop its balls after 5500-6000rpm????
wanado13's wrote:Has anyone taken a ae92 map gtz down the strip with pulley kit and reasonable frount mount. thinkin about takin my car down the strip and was just wonderin what times id be lookin at getting.
