Sway Bar. . . .cluncking could it be bent??
Postby Banga69 » Fri Oct 15, 2004 2:29 pm
as it says. . . . .could the sway bar be bent if it goes clunck. . clunck
CURRENT:
1994 Mazda Lantis
EX:
SOLD: AE101 GTZ ====>http://toyspeed.blakjak.net/profiles/profile.php?id=89
Banga69
Postby z|gen » Fri Oct 15, 2004 3:22 pm
i might be wrong on this..but im pretty sure its most likely your sway bar bushes need replacing when they make a clunking sound..
dont quote me on it..
correct me if im wrong..
- David
AE91 SUPERCHARGED COROLLA
z|gen
Postby deaf_rattle » Fri Oct 15, 2004 3:38 pm
yeah sounds like the bushing is buggered.
Postby 92GTApex » Fri Oct 15, 2004 3:58 pm
You could try packing the bush with a small strip of neoprene (???) and see if that gets rid of the sound
Thats what I did as a short term fix on mine, also realised alot of the clunking noise was coming from the bootlid not being adjusted correctly
Logan
Current ride: 92 Levin GT Apex
Current project: 91 Levin GT Apex (Crashed - It wasnt me)
www.area-51.co.nz
www.toyperformance.org.nz
www.lextreme.com
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1731
92GTApex
Postby Adamal » Fri Oct 15, 2004 4:03 pm
I'd say its the bushes as well. Do you find it happens when you go over speed bumps? I had that and replaced the bushes and it was fine.
Postby Leon » Fri Oct 15, 2004 5:13 pm
Also the link arms get stuffed too. Sorry, brain fade currently on the technical name for it...
Postby Dr-X » Fri Oct 15, 2004 5:23 pm
Sorry to hijack the topic, but could someone from a toyota shop help me out? I need new swaybar linkages and bushes for my 1995 Carina ED, and the parts shops round here dont list the items. How much for the genuine article, at toyspeed prices?
Dr-X
Postby Adamal » Fri Oct 15, 2004 7:07 pm
Send a PM to Mr Revhead :)
Users browsing this forum: Bing [Bot] and 16 guests
