Leon wrote:Spending every penny for the rest of your life, feeding the drug that is motor racing ... priceless.
Leon wrote:You need a cage built to certain specs before you can get it homologated, and therefore use it in MSNZ events, and therefore an authority card.
bIf it's a bolt together cage that came in from Japan, then you might as well chuck it away.
You can get a half cage put into most cars for less than $500 if you shop around. A half cage is good for basically any event except if you need a navigator.
ChaosAD wrote:Would removing a bolt-in cage when the cars on the road and replacing the back seat, then just replacing the cage (in the same car) whenits being used for events be counted as an 'alteration' and require re-homoligation?
Cos that way the car is still a 5 seater when not used at events.
Users browsing this forum: No registered users and 53 guests
