supercharger noise
supercharger noise
Postby ndeany » Mon Oct 18, 2004 9:39 pm
I currently have an ae101 supercharged levin. Upon boosting it, it makes a hell of a noise. I've narrowed it down to the supercharger. Has anyone got any ideas or thoughts? I've done a search on here but nothing really helps. I've got a spare supercharger, I was thinking that I could just swap them over, but I had a quick look today, looks like a bitch of a job to do. Has anyone do it before??
Cheers,
Nick
ndeany
NOISE
Postby GOLDAE86 » Mon Oct 18, 2004 10:13 pm
What kind of noise is it.Can u describe it any way.Drop me a pm and ur cell number and we can talk about it further.
To finish first, first you must finish
GOLDAE86
Real Life Mechanic
Postby Lloyd » Mon Oct 18, 2004 10:40 pm
They are a bit of a bitch to replace. FIrst thing to check would be the supercharger oil (dipstick around the back, you'll see a yellow wingnut with a bit of hunting)
Postby sopachrga » Mon Oct 18, 2004 10:48 pm
If the oil is low don't make the mistake of putting any old oil in there!!
(would be interesting though!)
the correct oil from a Toyota dealer is only about $12.50 for 50mls.
1987 S/C Manual AW11 (SOLD)
I don't have a Toyota anymore~!
sopachrga
Postby Mr Revhead » Tue Oct 19, 2004 11:43 am
also check the belt is worn and slipping
Postby FLAWLES » Tue Oct 19, 2004 5:54 pm
this is going to sound dumb but check ur intercooler for leaks mine had a credit card width gap in it and made a loud nosie and made the car fee rev
but what type of nosie like a nosie only when reving or what??????
FLAWLES
Postby ndeany » Tue Oct 19, 2004 6:19 pm
oil levels are sweet, as too are the belts and the intercooler. The noise sounds like a $&#$% bearing or something. It definatly sounds like a metal sound. Any thoughts
ndeany
noise
Postby GOLDAE86 » Tue Oct 19, 2004 8:50 pm
It sounds like the magnetic clutch on the supercharger has a flogged out but thats not 100% cause i haven't heard it. But wat u can do is disconnect the clutch to the supercharger by pulling the wiring to the unit off so the supercharger will not engage. If the noise is still present when driven, then take the belt off and drive it again. If u cant find it i am more than happy to look at it for ya. :? :?
GOLDAE86
Real Life Mechanic
Postby IH8TEC » Tue Oct 19, 2004 8:58 pm
there is a relay for the supercharger on the passenger side or the engine bay, on the firewall, has a little cover that says supercharger relay on it, there is a connector on that line between the relay and the supercharger, unplug that, (yes it will be gutless as :lol: ) see if the noise is gone then
and dont take the belt off, it has the water pump on it, and i really suggest you keep that going. :roll:
let us know
brendon
noise
Postby GOLDAE86 » Wed Oct 20, 2004 12:35 pm
U can take the belt of and drive for a short stint, but not to auckland and back obviously!!!!
GOLDAE86
Real Life Mechanic
Postby aesc » Wed Oct 20, 2004 12:55 pm
When my supercharger belt tensioner fell off I drove it for about 15 mins, very carefully of course and with one eye on the temp gauge. Temp didnt rise at all
EX AE101 owner
2013 Ford Focus ST
aesc
Postby ndeany » Wed Oct 20, 2004 4:40 pm
have pulled the relay off. The noise disappears. Must be the supercharger itself. Is it possible that the bearings could be $&#$% in it?
ndeany
Postby FLAWLES » Wed Oct 20, 2004 5:58 pm
ok now check the pulley bearing on the s/c " this is the most comon bearing to go " its the one in the s/c housing
then check the pulley bearing this is the next bearing to go
FLAWLES
Postby ndeany » Fri Oct 22, 2004 4:44 pm
ok, I've just had it checked out by a garage. Apparently the clutch on the supercharger is $&#$%. The supercharger is fine, just the supercharger clutch has seen better days.
ndeany
Postby FLAWLES » Fri Oct 22, 2004 5:52 pm
if u have takin the pulley of change the pulley bearing all it is is a a/con bearing about $50 this will save hassel latta on
trust me been down this road before :wink:
FLAWLES
