FF engine removal.
FF engine removal.
Postby kingcorolla » Tue Oct 19, 2004 7:48 pm
hey guys.
the runabout needs a new motor. so i picked up a donor car to do the swap.
i never removed a FWD engine b4, just want to know if the engine can be removed with transaxle attached?
1983 Carina AA63 4age
kingcorolla
Removal
Postby CAMB01 » Tue Oct 19, 2004 8:28 pm
Just drop the whole lot out the bottom. Easy as pie.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby kingcorolla » Tue Oct 19, 2004 9:47 pm
i usually just prefer to use the ol block and tackle..
why, is FF easier coming out the bottom?
kingcorolla
Postby Ae92typeX » Tue Oct 19, 2004 9:50 pm
Yep, can be done. drop under being easier if you can lift the car hugh enough, otherwise through the top some models I have worked on just need a bit of tilting to get clearance.
Ae92typeX
Postby Adamal » Tue Oct 19, 2004 9:54 pm
I'd probably undo the suspension at the tophats so you can pull the drive shafts out of the gearbox and then hoist it from the top.
How come you want to keep the transaxles connected anyway?
Postby Snoop » Wed Oct 20, 2004 2:38 pm
you dont need to take the struts out to take the drive shafts out if thats what your saying Adamal, but im not sure that is what your saying :?
just undo ball joints and tie rod ends then pull axles out, no prob.
yes, the engine can be removed with the transaxle attached.
A plan so good my head would explode if I even began to know what I was talking about...
Snoop
Postby kingcorolla » Wed Oct 20, 2004 4:03 pm
cheerz for the help guys.
My original box is fukd, so im swapping the box's too hence the question. :wink:
should be gravy from there, mind you, its an ford E5 engine.. :oops:
kingcorolla
jrs
Postby JRS » Thu Oct 21, 2004 2:58 am
u dont even need to undo any ball joints, just undo the 2 bolts connecting the strut to the hub carrier. undo the cv nut and u can just tilt it all to one side and pull the cv out of the hub. (doesn't apply to hondas)
meh.....
JRS
