levin_it_large wrote:are they aftermarket enkei wheels, if so it may need hub rings because it being just off, a few mm's can do alot.
What are hub rings excatly?
Once you get them balanced and aligned you'll probably find that it still pulls to the left a bit, its supposed to that that (a bit, not a lot)
