High speed Car vibration
Postby DJ » Sat Oct 23, 2004 8:20 pm
When I get over 90kph the steering wheel starts to vibrate badly and the car a little bit also, I though it may be the front wheels may need re-allignment but Ive been told it may be something to do with the enkei alloys on it, little help?
Car is a 91 N/A SW20
DJ
Postby Adamal » Sat Oct 23, 2004 8:40 pm
I'd say your wheels need to be balanced.
Postby keiichi » Sat Oct 23, 2004 11:13 pm
Yeah, get em balanced.
My car did exactly what you described, got them balanced two weeks ago and it has been driving smooth as ever since.
keiichi
Postby pidge » Sat Oct 23, 2004 11:13 pm
Also check for flatspots inthe tyres...
pidge
Postby Ae92typeX » Sat Oct 23, 2004 11:14 pm
Adamal wrote:I'd say your wheels need to be balanced.
I second that :wink:
Ae92typeX
Postby DJ » Sat Oct 23, 2004 11:32 pm
Aligned or belanced?
Cause I got the wrong one last time :P
DJ
Postby keiichi » Sat Oct 23, 2004 11:45 pm
I'm pretty sure its just balancing. I think if alighnment is out it will pull to one side.
I just got my front two wheels balanced as my steering wheel shook like mad on the motorway, is sweet as now.
keiichi
Postby Adamal » Sun Oct 24, 2004 12:11 am
Yea, alignment is for ensuring that your car goes straight when the steering wheel is straight. Keeps wheels parallel to each other.
Balancing is to keep the rotational inertia in check, making sure that it doesn't make the forces act to the left or the right while rotating.
Postby DJ » Sun Oct 24, 2004 12:15 am
I tried letting go of the wheel and it keeps pulling to the left
So Ill just go and get both done meh guess :?
DJ
Postby keiichi » Sun Oct 24, 2004 12:24 am
yeah, good idea...
although my car stopped shaking it tends to pull to one side still, should get alighnment too but.. meh
keiichi
Postby levin_it_large » Sun Oct 24, 2004 9:08 am
are they aftermarket enkei wheels, if so it may need hub rings because it being just off, a few mm's can do alot.
levin_it_large
Postby B_giB » Sun Oct 24, 2004 9:44 pm
levin_it_large wrote:are they aftermarket enkei wheels, if so it may need hub rings because it being just off, a few mm's can do alot.
hub rings will probably be it, so i take it the hub rings i got u levin_it_large the ones i got u are sweet then
Current: SXE10 Altezza
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby DJ » Mon Oct 25, 2004 9:01 pm
What are hub rings excatly?
Yeah they are aftermarket enkei alloys btw
Im going to get the wheels balanced / alligned torommow
DJ
Postby Lloyd » Mon Oct 25, 2004 9:10 pm
Once you get them balanced and aligned you'll probably find that it still pulls to the left a bit, its supposed to that that (a bit, not a lot)
Postby B_giB » Mon Oct 25, 2004 10:10 pm
they are plasitc or metal rings that make the wheel sit nicely on the hub, instead of sitting a little off center
not supposed to, it just does from the camber of out $&#$% up roads, unless it has a fully adjustable susspension (caster, camber and toe) it will never drive straight
B_giB
Postby DJ » Mon Oct 25, 2004 11:27 pm
Thanks for the help fellas :D
DJ
Postby JT » Tue Oct 26, 2004 4:57 pm
Has just come up with my car. Got it balanced, but its not that. Next check is the wheel bearings, jack up the car and shake the wheel holding it at the top and bottom. If it's not that the only other thing is can be is the steering, either play in the tie rod or rack end. Mine is the left rack end, go figure last thing on the list and hardest to fix.
JT
Car shake
Postby L8TR » Tue Nov 02, 2004 12:01 am
If you have done every thing and it is still shakey check that your tyres are completely round, jack up the wheel hold a piece of chalk in one spot
and spin it, then measure the thickness allround, should be the same,
I had this once with two brand new tyres and they came out of the mould
egg shaped $300.00 a pop they swapped for replacements, and said it does happen.
goodluck
L8TR GATOR
L8TR
Postby rallymazda » Tue Nov 02, 2004 7:26 pm
has the problem occured since you fitted the rims to the car? had a similar problem with a AE101 where the hub size was to small (or big cant remember) causeing the wheel to sit like this / only not on such an angle
solution was in this case to buy new mags as didnt want spacers
[4AGE8U] << my old number plate
Got me a new altezza, now arrived
1991 corolla wagon- work hack
rallymazda
Postby Just_Juzz » Tue Nov 02, 2004 7:48 pm
One rim may be buckled?
Are they new or second hand?
Current Ride: 1998 Caldina GT
Me, me, me, me.....
Just_Juzz
