Caldina - plug going nowhere? wtf..
Postby snwtoy » Sat Oct 23, 2004 9:21 pm
What is this plug for? It wasn't plugged in when I got the car, and if I feel around inside I can't reach anything that it might have been connected to. Have checked with another owner and theirs goes nowhere also... it's a mystery!
These images pretty much sum it up (rear hatch opened if you can't work out where the pics are taken):
snwtoy
Postby Monsterbishi » Sat Oct 23, 2004 9:35 pm
It's either a rearscreen demister that's not hooked up, or a glassmount antenna that's not hooked up.
Considering it has two wires, it's most likely a demister, all you have to do now is find where the rest of the wire has gotten to...
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby gt-trainer » Sat Oct 23, 2004 9:43 pm
id say its a demister, as the aerial is on the side windows i think. does ya demister work?also what prompted ya to look at it :?: :?
gt-trainer
Postby TWSTD » Sun Oct 24, 2004 9:11 am
yeah - antenna is on the side windows at the rear - although only 1 window will be hooked up - on mines its left rear. Theres a small signal booster just under the roof lining. You mystery plug has to be demister - god know what else it could be!
Click here!
TWSTD
Postby snwtoy » Sun Oct 24, 2004 1:28 pm
The wires for the demister are in the bottom left and rignt corners of the window. I am 100% sure that the demister works.
Al - go check yours out and I guarantee it's not plugged in either :)
Is the signal booster connected by default? Cos my reception is crap (crappy band expander?).
I went to look at it cos I was looking for the aerial - sometimes it's easier to plug a band expander into the aerial end - in this case I settled for pulling the stereo out.
So the side windows - one is for aerial and the other is for the gps thingy?
snwtoy
Postby TWSTD » Sun Oct 24, 2004 4:08 pm
The signal amplifier for the stereo should be plugged in by default, however you have 6to make sure its getting 12v from up front... from memory its a black wire with red stripe - if you dont have the head unit remote 12v out hooked up to it you wont hardly get any decent reception. In saying that i cant get george FM that well either - and mined hooked up!
Click here!
TWSTD
Postby YTWGN » Mon Oct 25, 2004 1:08 pm
Mine is unplugged also..
There is no sign to where it even should lead to.
YTWGN
Postby atmosports » Mon Oct 25, 2004 1:35 pm
Alot of car manufactures use a generic wiring loom for parts of there cars that is used on numeorus models & as such the plug you are referring to could do nothing on a caldina but on another car could be used. Engine bay looms are usually the worst for this as some manufacturer's basically have all the plugs for their various engine/gearbox combo's in the one loom.
atmosports
Postby TWSTD » Mon Oct 25, 2004 3:14 pm
well i dont know what you guys are missing - but ive certainly got it whatever it is!
check it out!
R E S T E K P A
Click here!
TWSTD
Postby YeMs » Mon Oct 25, 2004 5:54 pm
maaaaaaybe its an ariel? dont sum japanese cars have ariels built into the window? like cellphone ariels or something?
Your local Hybrid Elite tech
YeMs
Postby gt-trainer » Mon Oct 25, 2004 6:46 pm
yip mines the same as twstds sure ya dont need two pics but!weird aye?
yems ya might wanna read above regardn aerial.
gt-trainer
Postby Farmer_dave » Mon Oct 25, 2004 10:34 pm
The mystery continues.
TWSTD Any chance you could rip your boot apart and find out where those wires go?? :D
Very weird how some are connected and some arent.
Im real curious now. :?
My Profile:
Now updated with a new pic
http://toyspeed.blakjak.net/profiles/profile.php?id=201
1997 Caldina GT-T
Farmer_dave
Postby Inane » Tue Oct 26, 2004 4:29 pm
I'm hanging to get home and check mine out now!!
Inane
Postby KinLoud » Tue Oct 26, 2004 5:22 pm
It's the Bling mind controller aerial.... standard on all GTT caldinas!
Paid for jointly by all the aftermarket turbo manufacturers.
"HMMMMMM MUST HAVE MORE BOOOOST"......
"MUST ORDER HUGE TURBO".......
he, he
Ken
Ham
021 408 863
Postby snwtoy » Tue Oct 26, 2004 10:27 pm
Ok so that's 2 with and 2 without...
Mine's a 97 (manual)... without connection
Others are... ?
Now I REALLY wanna know!!!!!!!
snwtoy
Postby Inane » Wed Oct 27, 2004 10:44 am
KinLoud wrote:It's the Bling mind controller aerial.... standard on all GTT caldinas!
he, he
Ken
Ham
021 408 863
can't........find........plug.......must....get..bigger....turbo......
Inane
Postby HERGTT » Tue Nov 02, 2004 9:31 pm
Ok, after reading this I had to go and check mine....
1999, Manual - PLUGGED IN :D
I just hope that there is a good reason why it is plugged in, anyone found out anything further on this mystery plug??
HERGTT
Postby snwtoy » Tue Nov 02, 2004 9:58 pm
For some reason I'm insanely jealous of an unknown plug that I don't have :cry:
snwtoy
Postby Digitizar » Tue Nov 02, 2004 11:19 pm
im no caldina owner, but heres a pic i ripped out for ya, hope it sumhow helps: :roll: i think 86392 is the cover u remove, and 86101r is the plug which seems to go to ther right window. but i could be wrong..
AE111 Levin Light man a fire and u'll keep him warm for a day, light a man on fire and u'll keep him warm for the rest of his life..
Digitizar
Postby Inane » Thu Nov 04, 2004 9:09 am
Mines unplugged!!!
Inane
